Icebox install question...
Old Jan 21, 2004 | 01:33 AM
NiteQwill's Avatar
Adventurist.
Do you really need to flush/bleed the coolant system as per directions?
Old Jan 21, 2004 | 01:56 AM
mattg's Avatar
no. i have no idea what they are talking about.
Old Jan 21, 2004 | 02:08 AM
NiteQwill's Avatar
Adventurist.
Good to hear, it would have been another step that just a PITA to deal with
Old Jan 21, 2004 | 02:12 AM
sidemarker's Avatar
i think once you remove the VSA tube and breather tube you will have some coolant come out so be careful!
sidemarker
Old Jan 21, 2004 | 02:16 AM
NiteQwill's Avatar
Adventurist.
sidemarker
With this, it still doesn't need a flush/bleed, correct?
Just trying to get my steps right before I install.
Old Jan 21, 2004 | 04:07 AM
mattg's Avatar
i just installed my icebox and no coolant came out. again, i have no idea what they mean about flushing/bleeding the coolant system. this is the 3rd intake i have installed on my cl-s and i have never had a problem.
Old Jan 21, 2004 | 05:31 AM
Slimey's Avatar
Where is my super sauce?
Yes, you should bleed the air out of your system after you change the tubing. A large air bubble in the system is not going to be effective to cool the cylinder/block.
It's a pretty easy process - at least my poor man's version of it. If you are really anal you may want to do a complete coolant drain/refill procedure, but this'll do.
First off, you will lose some coolant when changing the tubing, so buy some Honda Type II coolant (premixed) before you install the IceBox as you may need to top off the system. It's good to have a jug of this in the garage as it is. Now is the time to buy some.
After the install you'll want to get the air bubbles out of the system. Remove the cap to the radiator. Turn on car and warm it up in idle about 10 minutes (IIRC, I think technically it's warmed after the radiator fan cycles twice). Turn up heater to max (IIRC, set auto to 90ºF) to open the heater core so the coolant circulates freely. During this process tap/jiggle the the coolant hoses (especially the large upper one) to move the larger bubbles to the top. Don't hurt your fingers -- be careful. You should see several large bubbles percolate through the opening that the cap goes too.
After a few minutes of this the bubbles should stop. You have now bled your system of bubbles. Top off any lost fluid in the radiator or reservoir, put on cap, turn off engine.
Enjoy the IceBox.
Old Jan 21, 2004 | 05:36 AM
mattg's Avatar
interesting. certainly not necessary imo.
steve, what do you think?
Old Jan 21, 2004 | 06:13 AM
scalbert's Avatar
Just to be sure:
Old Jan 21, 2004 | 06:26 AM
mattg's Avatar
i better go and burp my cl.
actually i have a gallon of coolant and a bottle of water wetter waiting to go in. you don't have to use the honda brand coolant though, right?
Old Jan 21, 2004 | 06:50 AM
scalbert's Avatar
I did but there is a Honda dealer near my house so it was convenient.
Old Jan 21, 2004 | 08:23 AM
fuzzy02CLS's Avatar
No, I see no reason in real life as to why this is even suggested. I didn't do it either when I put in the low temp t-stat & fan switch. This is the only car I have ever heard of doing such a thing.
Old Jan 21, 2004 | 08:27 AM
scalbert's Avatar
Huh, all cars should have their cooling system bled if air is potentially introduced. This is standard for all vehicles, domestics and imports and is common knowledge.
Count your self lucky that you are not experiencing any cooling issue; or maybe your system is not operating at peak efficiency.
Old Jan 21, 2004 | 09:47 AM
NiteQwill's Avatar
Adventurist.
Good info! Well, being anal retentive, I'll bleed the coolant system, shouldn't take more than 15-20 minutes anyway.
Old Jan 21, 2004 | 04:54 PM
Slimey's Avatar
...This is the only car I have ever heard of doing such a thing.
Last year, when I searched how to do this, I think I got like 1000 hits from a bunch of auto forums on all makes of cars.
Burping the coolant system seems like a pretty common process to me. In fact bleeding our system is easier then some other cars. Some cars have bleeder valves on the radiator that need to be open and purged during the process making it slightly more complicated.
When I did this after installing the IceBox, I saw several decent sized bubbles percolate out -- I'd hate to have those locked in some of the finer tubing of the cooling system.
Old Jan 22, 2004 | 07:25 AM
fuzzy02CLS's Avatar
Don't know where I've been then. I never heard of it. Good to know.
Old Jan 22, 2004 | 07:02 PM
BC's Avatar
BC
nearsighted visionary
MattG. I would use the Honda coolant. A couple of years ago there was a high percentage of water pump failures w/gold wing motorcycles. Cause was traced to silicates (think sand and glass) present in other than Honda coolant.
Old Jan 23, 2004 | 12:23 PM
philgates's Avatar
Do you have to reset and re-train the ECU after the IceBox install?
Old Jan 23, 2004 | 03:53 PM
Slimey's Avatar
Yes. Here is how you do it:
1) Turn car on.
2) Drive.
The ECU is constantly 'learning'. There is no need to disconnect the battery or fuse. Steve (scalbert above) has debunked this myth with his ECU monitoring data.
Old Jan 23, 2004 | 03:55 PM
mattg's Avatar
thanks for the info BC.
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
Nitin
Sep 30, 2015 08:22 PM
TxRzrBk
Sep 17, 2015 01:07 PM
Leester01
Sep 11, 2015 06:35 PM
