IAT - Pre/Post Thermoblock
#204
Received 1,080 Likes
Originally Posted by ndawood
Just a note to everyone who has installed or is planning on installing the spacers. Be sure to check your coolant and oil levels once a week to ensure that they are at their adequate levels. I noticed today that my coolant was low and after I did some more research I found that it is common to use up some of the coolant and the oil may start to burn a little. I didnt notice any change in the oil level. I am currently running amsoil 5w20 so I wasnt expecting much of a change but I will keep a close eye on it. I just wanted to give everyone a heads up on this mod!
Where did you read that? What does oil/antifreeze usage have to do with the spacers?
#205
Originally Posted by juice
Can someone take a picture and point out what needs to be modified on the plastic cover to get it to go back on? Thanks
I used my drill with a grinding wheel. Took less than five minutes to grind the opening a little longer. Can't really tell any modification t0 the engine cover was made unless you look close.
Today is the first day that I had my car out for an extended drive since the install.
The top of the plenum cover was much cooler than before the install. Before the install the cover was hot to the touch and now it was only moderatly warm.
For the price, not a bad engine mod.
#206
Originally Posted by Louie11
Will be ordering mine soon too. Hows it feel dj5. Still like to see what johntypes comes up with the dynos at garage kwai. The weather here does suck I don't mind the cold(either does the car) I just hate this snow and salt crap. I thought it would be over by now.
I have been over to Geoge Kwai's shop a couple of times. I am out in the western suburbs so Kwai's shop is a little out of my way. I started using GRD here in Naperville. They tuned my Unichip and install my UR crank pulley.
I agree with the salt crap, it's hard to keep a car clean and pick up a lot more hood chips from the salt being kicked up. I can't really feel much of a difference, guess my butt dyno is not sensitive enough to pick up 7-8 hp. The plenum cover is much cooler, so in theroy I would say it delivers some gains.
#207
Since the TB spacer is used, the MAP sensor moves to the right (towards the battery)... so the cutout on the engine cover for the MAP gets in the way and needs to be widened.
If you only use the manifold spacer, then no need to cut anything.
#208
I called Outlaw Engineering today and spoke to Shawn Morgan. I asked him if he knew the status of the group/bulk buy for us. He stated that a few people have called and questioned him, but nothing has been set up. He recalled giving someone the priceing.
He also said that a board member or moderator normally sets everything up. He said that he will take a more proactive approach and contact someone, if needed.
Is someone setting this up? If not, who does he need to contact? Does anyone remember the quotes that he gave them?
Also, he said that it may save us 10%. I am not sure if that will be worth the wait. It will probably take a few weeks to get this together.
juice
juice
#209
he needs to contact Astroboy
#211
i don't know. why don't you PM him and find out what would be best.
#212
How long does it normally take to get a GB together. I have some free time this weekend to do the install. I may order it tomorrow and hope that I get it Thursday. $10 is $10, but I don't know if I can wait.
#213
You can contact me on the group buy, I'll help move things forward as best as I can.. If someone can provide me with all the info that has been gathered so far please send me a PM or a email to swjones88@hotmail.com
#214
ex 6 Speed owner :(
#215
I just ordered mine. I hope I get it Thursday because i want to install it on Friday. I did not want to wait on the GB.
What will I need other than basic tools, TB cleaner, and gasket remover? Can I use the TB cleaner to remove the gasket?
Does it come with 4 gaskets, one for each side of the TB spacer and one for each side of the intake manifold?
#217
#218
#220
Adventurist.
Originally Posted by mrsteve
Matt, did you replace the manifold gasket? How did the stock one look when you opened it up? I'm contemplating replacing the gasket when I do the IC install.
Juice:
The kit come with 3 gaskets. Two for each side of the TB and one for the top of the IM Thermoblok gasket.
You need a torque wrench, a gasket scraper, 10, 12, 14 mm sockets with ratchet, TB cleaner, and a set of open spanner wrenches (comes in handy when removing the studs).
#222
How do you guys feel this would effect the performance of an engine when used in combination with the Mugen Cooling Mods? I am not SC'ed at the moment but considering squeezing this summer and want to get the engine mods needed to run it all safely. The outlaw spacers are going in for sure, but as for the Cooling mods, needed or not?
#223
Originally Posted by dj5
Louie11,
#225
Originally Posted by NiteQwill
When I opened up mine, it looked fine. I don't see a need to replace it.
#226
my car has ~ 62K
#228
#229
I take it that we are supposed to reuse the existing IM gasket under the thermoblock. thanks
#230
if you guys need photos of the intstall you can go to http://www.phytte.com under photos. Thanks niteqwill and edddie for the hosting!!! Great photos too!
#232
Lead Footed
Ruf
#234
this is a little beside the thread topic but has people here removed their engine cover? The engine cover seems like it keeps a lot of the heat and I'm thinking if you removed it it would keep the engine bay a little cooler resulting in maybe couple HP?
#236
If you guys are thinking of buying the spacers anytime soon sit tight for a few days.. I'm talking with them now trying to set something up for the CL/TL guys.. I'll let keep you guys updated..
#237
Lead Footed
Ruf
#238
Lead Footed
Ruf
