i need help asap!!!!!! pls
Old Nov 13, 2007 | 02:15 AM
RTizzo's Avatar
for some reason the key wont turn. the steering wheel lock is on. no matter how i turn the steering wheel to release the lock, the key wont turn at all. first time this has happened to me. any ideals or suggestions?
Old Nov 13, 2007 | 03:01 AM
ironsurfer129's Avatar
CL-Pride
wont turn to on? or wont come out? is ur gear in park? keep turning steering wheel and turn the key together.
Old Nov 13, 2007 | 06:17 AM
SPoolinspOON's Avatar
OG 3.x^7 rawr
turn the steering wheel clockwise. It should only move about an inch. hold it at that position and turn the key.
Old Nov 13, 2007 | 10:47 AM
RTizzo's Avatar
the key wont turn at all when i put it in, ive tried every gear, every steering wheel position.
Old Nov 13, 2007 | 11:02 AM
fuzzy02CLS's Avatar
Makes zero sense. If the steering wheel lock is on you need to turn the wheel & the key at the same time to unlock it.
Does the key go in & come out ok?
Old Nov 13, 2007 | 11:32 AM
RTizzo's Avatar
yes i know how to unlock the steering wheel lock, i do it all the time. the key does come in and out no problem. once its in i cant turn it at all. tried spraying shitload of wd40. key still wont turn. this makes zero sense to me too but luckily my car is just parked at home.
Old Nov 13, 2007 | 12:07 PM
fuzzy02CLS's Avatar
Do you have another key to use? Like the valet key? Maybe there's something wrong with the key.
Time to get a locksmith.
Old Nov 13, 2007 | 06:04 PM
RTizzo's Avatar
tried all 3 keys already it wont turn
Old Nov 13, 2007 | 09:08 PM
o1s's Avatar
o1s
pins in the cylinder might possibly be damaged. did you accidentally put another key in it and try to start it?
Old Nov 13, 2007 | 11:12 PM
rush's Avatar
03 acura cl type s
i need a clutch
Old Nov 13, 2007 | 11:21 PM
shredoption's Avatar
Originally Posted by rush
i need a clutch
What? It's an '01 what does a clutch have to do with anything?
Old Nov 14, 2007 | 02:04 AM
underst8's Avatar
140,000 miles young
he is attempting to hijack.
RTizzo i'd recommend posting in the 1g cl forum - they had a lot of issues with ignition cylinders, etc...and they might be better able to help u diagnose your problem if it's something along those lines. GL
Old Nov 14, 2007 | 08:30 AM
fuzzy02CLS's Avatar
If all 3 keys don't work, then something is wrong with the cylinder.
Old Nov 15, 2007 | 11:24 AM
Harrisonk531616's Avatar
CL-SEXY SIX (=
Your IGN. cylinder is worn out...
-1 put key in ignition
-2 get hammer and tap it from behind and then try
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:38 PM
njresendez
3G TL Photograph Gallery
Sep 21, 2015 06:32 PM
