i cant chirp into 2nd anymore???
///M POWER
1 Post
i used to allways chirp into 2nd like a month ago, but now i cant get a bark out of them on the shift
i think its because i got the tranny fluid flushed, thats my only guess, i mean it was 35 deg tonite and the car is pulling crazy so i know the power is there
anyone have a clue??
Parting out 02 Type S :(
i still cant believe you guys think its normal for us to chirp in the first place. the auto tranny should be smooth at top shifts. it chirps because the shift is not smooth, very harsh and sudden as if the car didnt expect to shift.
getting tranny fluid flushed probably made the tranny run smoother, thus no harsh shifting and no chirping tires.
you guys are confusing chirping with too much power, which is not the case here.
i never chirp any gear ever. but does it mean there isnt enough power!?
VOTE OUT THE BUSH REGIME
Originally posted by CLS2001_97124
I've always thought when the streets are hot, you chirp your tires more?
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
bingo he hit the nail on the head. I can vouch for this living in phoenix where the assphault is always hot enough to cook an egg(or bacon
when its summer my tires chirp everywhere, come winter the chirping stops unless I take a hard corner and floor it
Ditto on what power3dfx said. If your tranny is stock, well maintained, and the tires aren't bald you should have smooth launches. I put a shift kit and high stall converter in my truck. Now I chirp my tires at will. Unless I have 800 lbs of tools and parts in the back. Which is the reason for the high stall converter, it helps get the load moving.
Beware of leakage
When it was still hotter than hell here with rapidly dissintigrating tires I spun almost all the way through first gear from dead stop. Now that it's cooler with better tires traction will be better =)
Originally posted by darrinb
warmer= better traction
colder= shittier traction
i thought u guys knew this
when the road is between 70-80 degrees, it gives optimal traction. if its really hot, then the tires can heat up too much, and they start slipping instead of gripping. if you watch car racing (not bs kinds, i mean the type like BM), they will always start to slide more because the tires are too hot.
anyone whos been to a track knows that after several laps, the cars start to slide.
Blackbird baby..
Originally posted by cor
was that a monty python reference?
Acura604
2G RDX Photograph Gallery
17
02-08-2021 03:32 PM
SidhuSaaB
05-30-2020 12:40 AM
RSpyder
09-30-2015 12:46 AM
