How to replace the brake lines?
Old Mar 28, 2006 | 12:59 AM
Bobbydoedoe's Avatar
I'm Cool
I got a question, how exactly do you replace the brake lines?
do you just drain all the brake fluid out and than replace the line when the system is dry?
thanks for the help
Old Mar 28, 2006 | 01:10 AM
Allout's Avatar
Blown is Best
Just do it with fluid in the system and use a pan to catch the fluid. You'll have to bleed the system once you're done anyways. I would try to keep fluid in the reservoir to keep air from entering the upper part of the system (master cylinder, ABS pump). I always use line wrenches instead of standard open end wrenches so I don't strip or damage the fittings.
Old Mar 28, 2006 | 01:14 AM
saiko_cl_duck's Avatar
i kept the top off of mine reservoir and filled it as necessary, and tried never letting it get below minimum. It's good to have a friend around to help.
it's also a good time to change rotors/calipers/pads while you have everything apart. I'm waiting to get my rotors in before i do the lines
mada51589
Jan 9, 2025 04:40 PM
yesSIR-S
May 13, 2016 05:42 PM
02tljj
Sep 11, 2015 12:37 PM
asahrts
Sep 4, 2015 05:55 PM
nishant11
Sep 2, 2015 10:34 AM
