How to remove the steering wheel??
Old Jan 5, 2010 | 03:13 PM
PAYMEE's Avatar
G.uns O.n D.emand
I GOT QUOTED $144 BY LOCAL DEALER TO DO MY 01 BLACK BURLWOOD STEERING WHEEL SWAP... KINDA PISSED OFF AT THE PRICE...I ASKED WHATS THE LABOR TIME..TELLS ME 1 HOUR...WHAT A JOKE
ANYWAY CAN I DIY THIS?? I SEARCHED AND REALLY DIDN'T FIND ANYTHING TOO HELPFUL...ANY INFO IS APPRECIATED?? HERE IT IS...I GOT IT ON EBAY FOR A PRETTY GOOD PRICE..I LOVE IT..
Old Jan 5, 2010 | 03:57 PM
civicdrivr's Avatar
I dont have my shop manual here, but you need to remove the airbag, unbolt the big nut holding the wheel on (probably a 19mm, its been awhile), unplug the cruise and radio buttons, and pull.
Old Jan 5, 2010 | 04:11 PM
CL-Slick's Avatar
Chillin' in my trailer
Might need to pick up a steering wheel puller, not 100% sure though. Nice looking wheel though!
Old Jan 5, 2010 | 04:25 PM
hot_cls's Avatar
Reppin CALI 619
it can be done in less than an hour. i swapped mine in like 20-30 mins. there is a diy for this. search for it my friend.
Old Jan 5, 2010 | 04:58 PM
ChucksCL-S's Avatar
Disconnect battery, wait three minutes. Air bag system should be disarmed by then. If I remember right remove screws on side area of steering wheel, it will all pull off. Remove air bag bolts and radio/cruise connectors and big nut holding on the steering wheel, it should wiggle off with some force. MAKE SURE WHEELS ARE POINTED STRAIGHT AHEAD AND NEW STEERING WHEEL IS STRAIGHT TOO! I missed this the first time and had to do it over.
Old Jan 5, 2010 | 05:18 PM
MrFluffy's Avatar
To many cars in my garage
where did u get that steering wheel , it is nice I want one
Old Jan 5, 2010 | 05:49 PM
brianlin87's Avatar
ASM I.S. Design FTW.
this procedure is fairly simple. it can be done in like 15 mins. just don't overthink the procedure.
Old Jan 5, 2010 | 06:59 PM
ACRIIGHT's Avatar
It must be that time of year! I just got mine today also. I'll post pics tomorrow. I got the beige prefforated leather with the burlwood. I found it on ebay last week, BNIB for a 2002-2004 MDX, $99.
Old Jan 5, 2010 | 09:04 PM
Allout's Avatar
Blown is Best
These are the installations instructions for a 2001-2002 Accord which are identical to the CL. Hope this helps:
http://www.handa-accessories.com/accord/accwoodwhl.pdf
Old Jan 5, 2010 | 09:05 PM
friesm2000's Avatar
B A N N E D
you have to swap over everything else to the new wheel too, but should not be too long of a job
for a steering wheel puller, not geneally needed on our cars, just shake the wheel back and fourth and it should come free
OP, just be extremely careful with the airbag, they can be deadly if you make a mistake with them, so as said before, disconnect the battery beforehand (makes it alot safer)
Old Jan 5, 2010 | 09:06 PM
civicdrivr's Avatar
And dont reconnect the battery until after everything is done.
Old Jan 5, 2010 | 09:44 PM
Allout's Avatar
Blown is Best
Just follow the factory Honda instructions and you'll be fine.
Old Jan 5, 2010 | 10:06 PM
p.diddy's Avatar
Originally Posted by FUKUPAYMEE
ive been wanting that steering wheel for a while now or a '03 all leather wheel.
Old Jan 5, 2010 | 10:56 PM
PAYMEE's Avatar
G.uns O.n D.emand
ITS ON EBAY...I HAVE WANTED THIS SINCE I GOT MY CAR 2.5 YRS AGO
THANKS BRO...I THINK I'M GONNA ATTEMPT THIS INSTALL
YUP...EXACTLY WHAT I NEEDED...THANKS!!
THANK YOU!!!
WELL SINCE YOU GUYS HAVE BEEN SO HELPFUL I'LL SHARE WITH MY A-ZINE BROTHERS...
DIDDY FLUFFY HERES THE LINK:
GENUINE ACURA TL CL BLACK WOOD & LEATHER STEERING WHEEL
Old Jan 5, 2010 | 10:58 PM
PAYMEE's Avatar
G.uns O.n D.emand
I'm just a little worried about the torq wrench thing tho...i don't have one and never used it...do i need to do this to complete the install??
Old Jan 5, 2010 | 11:18 PM
civicdrivr's Avatar
Just make sure the bolt is tight.
And I highly recommend that seller. I get all my parts from them (they're local). Theyre cool people. And if you call them you may be able to get a better deal. Talk to Chris or Rob.
Old Jan 5, 2010 | 11:26 PM
PAYMEE's Avatar
G.uns O.n D.emand
just make sure the bolt is tight.
And i highly recommend that seller. I get all my parts from them (they're local). Theyre cool people. And if you call them you may be able to get a better deal. Talk to chris or rob.
lol.. Wish i would have known that before i plunked down my $176...i was just so damn happy to find one of these for less then $300...i have bought a few things from them...they are great..highly recommend
Old Jan 6, 2010 | 01:24 PM
saiko_cl_duck's Avatar
https://acurazine.com/forums/1g-cl-diy-faq-74/1st-gen-cl-steering-wheel-diy-w-pics-486041/
It's the same as the first gen CL. I even used the 2nd CL wheel as a replacement.
Old Jan 6, 2010 | 02:33 PM
p.diddy's Avatar
Damn 50% off. That $300 price tag is the reason I haven't bought one yet.
Old Jan 6, 2010 | 03:39 PM
phee's Avatar
I got the Shifts
Disconnecting the Airbag Connectors, Side Airbag Connectors, and Seat Belt Tensioner Connectors
Before removing a front airbag, side airbag or other SRS related devices (the SRS unit, the cable reel, the side impact sensors and the seat belt tensioner connector), disconnecting connectors from related devices, or removing the dashboard or the steering column, disconnect the airbag connectors or the side airbag connectors to prevent accidental deployment.
Turn the ignition switch OFF and disconnect the negative cable from the battery, and wait at least 3 minutes before beginning the following procedures.
Before disconnecting the SRS main harness 18P connector (A) from the SRS unit, disconnect the driver's airbag 4P connector (C), the front passenger's airbag 4P connector (D), the driver's seat belt tensioner 2P connector (G) and the front passenger's seat belt tensioner 2P connector (I).
Before disconnecting the SRS floor harness 14P connector (J) from the SRS unit, disconnect both side airbag 2P connectors (K, L).
Before disconnecting the cable reel 4P connector (B), disconnect the driver's airbag 4P connector (C).
Before disconnecting the SRS main harness 4P connector (E), disconnect the driver's seat belt tensioner 2P connector (G) and front passenger's seat belt tensioner 2P connector (I).
Disconnect the negative battery cable, and wait at least 3 minutes .
Driver's Airbag
Remove the access panel from the steering wheel, then disconnect the driver's airbag 4P connector (A) from the cable reel 4P connector (B).
Front Passenger's Airbag
Remove the glove box, then disconnect the front passenger 5 airbag 4P connector (A) from the SRS main harness 4P connector (B).
Side Airbag
Disconnect both side airbag 2P connectors (A) from the side wire harness 2P connectors (B).
Seat belt Tensioner
Disconnect both seat belt tensioner 2P connectors (A) from the side wire harness 2P connector (B).
Old Jan 6, 2010 | 03:43 PM
phee's Avatar
I got the Shifts
removal DIY
Removal
SRS components are located in this area. Review the SRS component locations, precautions, and procedures in the before performing repairs or service.
Align the front wheels straight ahead, then remove the driver's airbag assembly from the steering wheel.
Disconnect the radio remote switch connectors (A) and cruise control switch connector (B).
Loosen the steering wheel bolt (A), and install a steering wheel puller (B) on the steering wheel (C). Free the steering wheel from the steering column shaft by turning the pressure bolt (D) of the puller. Note these items when removing the steering wheel:
Do not tap on the steering wheel or the steering column shaft when removing the steering wheel.
If you thread the puller bolts (E) into the wheel hub more than 5 threads, the bolts will hit the cable reel and damage it. To prevent this, install a pair of jam nuts 5 threads up on each puller bolt.
Remove the steering wheel puller, then remove the steering wheel bolt and steering wheel from the steering column.
Installation
[img]http://alldatapro.com/alldata/PRO~V148578629~C35676~R0~OB0~P3R0H~N/0/80851247/83216606/84820068/84820071/34853741/34864218/34864219/34864540/34850103/99807717/87717942/89178732[img]
Before installing the steering wheel, make sure the front wheels are aligned straight ahead, then center the cable reel (A). Do this by first rotating the cable reel clockwise until it stops. Then rotate it counterclockwise approximately 2 and half turns. The arrow mark (B) on the cable reel label point should point straight up.
Position the 2 tabs (A) of the turn signal canceling sleeve (B) as shown, and install the steering wheel on to the steering column shaft, making sure the steering wheel hub (C) engages the pins (D) of the cable reel and tabs of the canceling sleeve. Do not tap on the steering wheel or steering column shaft when installing the steering wheel.
Install the steering wheel bolt and tighten it to 39 Nm (4.0 kgf-cm, 29 ft. lbs.) .
Connect the radio remote switch connector and cruise control switch connector.
Install the driver's airbag and confirm that the system is operating properly.
Check the horn, radio remote switches, cruise control set/resume switches and turn signal canceling for proper operation.
Old Jan 6, 2010 | 05:19 PM
ACRIIGHT's Avatar
Here it is...
Old Jan 6, 2010 | 08:13 PM
PAYMEE's Avatar
G.uns O.n D.emand
HERE IT IS... WOOD GRAIN WHEEL...AKA BOWLING BALL WOOD LOL...I LOVE IT...THANKS FOR ALL THE HELP GUYS...$144 TO INSTALL F U DEALERSHIP...I ABSOLUTELY LOVE A-ZINE MAN...
Old Jan 6, 2010 | 08:25 PM
Jacobpockros's Avatar
nice. you should try to get the 03 airbag cover now.
Old Jan 6, 2010 | 08:53 PM
phee's Avatar
I got the Shifts
nice man. did u use my instructions?
Old Jan 6, 2010 | 08:54 PM
p.diddy's Avatar
Originally Posted by jacobpockros
nice. You should try to get the 03 airbag cover now.
+1
Old Jan 7, 2010 | 10:19 AM
5thgen's Avatar
Trust Me I'm Better!
Never gonna happen. I've researched this and no one on here is brave enough to be the 1st to try it, if it can even be done at all. Your going from a single stage airbag to a 2-stage one. That's just for starters.
Old Jan 7, 2010 | 11:54 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
i did the upgraded steering wheel I still have the main hectic picture...
hopefully this will help
Old Jan 7, 2010 | 12:14 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Azine ftw
Old Jan 7, 2010 | 11:31 PM
CRV_33's Avatar
I would recommend a steering wheel puller and it came in handy when I did my steering wheel swap. I'm pretty sure you can rent it for free from a local Auto Zone. Just pay the deposit on pick up and you get it back once you bring the part back.
Old Apr 12, 2010 | 04:39 PM
brian6speed's Avatar
Lone Wolf
I tried to use a steering wheel puller and it pulled the bolt right out with the threading on the bolt so now there is no threading. I am screwed and dont know what to do now
Old Apr 12, 2010 | 05:19 PM
StreetKA's Avatar
DIY
https://acurazine.com/forums/showthr...8#post11910608
Old Apr 12, 2010 | 06:42 PM
Lone Wolf
Originally Posted by StreetKA
I didnt need a DIY I knew what to do. I was able to use force and yank it off without the puller thankfully.
Old Apr 12, 2010 | 07:16 PM
Allout's Avatar
Blown is Best
And this was with the center bolt removed?
Old Apr 12, 2010 | 09:12 PM
civicdrivr's Avatar
That happened to me twice. Put the bolts in further. They should grab onto some material and be able to pull the wheel off.
Old Apr 12, 2010 | 10:11 PM
phee's Avatar
I got the Shifts
the wheel comes off easy. no need for a puller
Old Apr 13, 2010 | 12:06 AM
nspec_ya4's Avatar
Regional Coordinator (Texas)
so are you saying that hole where the 14mm bolt goes doesnt have any threads left? thats pretty fucked up.
i think u'll have to replace the steering column if its just one piece.
Old Apr 13, 2010 | 12:52 AM
civicdrivr's Avatar
No, hes talking about the two holes that the puller bolts to. I had the same issue. It was annoying.
Old Apr 13, 2010 | 01:11 AM
nspec_ya4 did it....
Old Apr 13, 2010 | 08:31 AM
(Mid-Atlantic)
I had the same issue, just have to thread in farther, you really honestly don't even need the puller, you can just bear hug it, give it a couple of rocks back and forth and it should pop right out.
