How to remove oversized POLARGs in fogs?
Old Aug 17, 2002 | 05:14 PM
SilverBullet_RENAMED's Avatar
How to remove oversized PIAAs in fogs?
Guys, any advice on how to remove these out of my lights. I just tried slowly turning it, and whatever I can do to remove them since they are falling apart, the color. Anyways, how can I get them out without the bulb falling into the assembly?! I tried one and it almost came out. Thanks.
Old Aug 17, 2002 | 05:48 PM
NOVAwhiteTypeS's Avatar
shake , break, shake again
Old Aug 17, 2002 | 09:58 PM
rise's Avatar
Old Aug 17, 2002 | 11:52 PM
God's Avatar
God
GOD Of ACURA-CL.COM
break them inside of the light and just shake the pieces out thats the only way .
Old Aug 18, 2002 | 01:26 AM
Scooter's Avatar
'Cooter
NO, that's not the only way...simple, if it's not coming out by pulling from the unit, pull it such that the bulb comes out of its socket...then take a pair of needlenose pliars and grab the connector part of the bulb and pull...u'll have the leverage u need to take em out...only prob is u'll take the blue coating off with it
Old Aug 18, 2002 | 02:04 AM
I will try this tomorrow then. Thanks Scooter.
Old Aug 18, 2002 | 03:39 AM
BBsAcuraRacing's Avatar
GIve it up. I am on ,my 3-4 bulbs after 26k miles. They will swell so you cant get them out without breaking after the first one hour of use. I can now change a bulb in 2=3 mins without getting dirty . One screw holds in the housing and is removed from the front
Old Aug 18, 2002 | 12:19 PM
Where is this screw? Because the insturctions on FAQ are down? Thanks.
Old Aug 18, 2002 | 01:49 PM
JRock's Avatar
Old timer
Uh if you're accessing the back of the roadlamp, you already removed the screw he's talking about.
Old Aug 18, 2002 | 01:56 PM
Zapata's Avatar
Cost Drivers!!!!
break it.....once it swollen that's it.........
Old Aug 18, 2002 | 03:33 PM
gto2050's Avatar
Someday pigs WILL fly!
Mebbe not..... mebbe he reached up behind!
The screw is accessed from the front grill. You can see a hole where it is accessed. Loosen it (it doesn't come all the way out) and the light pivots from the outside.
Old Aug 18, 2002 | 05:40 PM
You don't have to remove anything to get the lights out. There is a whole your hand can get under the splash guard to access it. So I guess the screw is behind it to remove the whole assembly? If so, then I need to remove the splash guard to get behind it.
Old Aug 18, 2002 | 05:41 PM
Yep, I was accessing it from behind. Thanks, I will look for this screw.
Old Aug 18, 2002 | 06:14 PM
Got the bulbs out and put in the stock ones for now.
Any one know what bulbs would be good that won't burn or fall apart like these did? Thanks
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
rockyboy
Sep 29, 2015 12:05 AM
rhdune16
Sep 28, 2015 11:31 AM
