How much Tranny fluid?
MP Video Extraordinaire
I am going to change my tranny fluid this weekend at the Brother InLaw's garage. Should I use the Honda Premium fluid the book recommends and how much of it should I buy?
Thanx,
Chris
01 CL-S San Marino Red/Black, K&N drop in, no nav, rear wing, otherwise stock thus far, has an appetite for Bavarian cars.
Thanx,
Chris
Yes you should use the factory fluid,failure to do so can cause all kinds of problems.You will need 3 qts of the trans fluid and the correct sealing washers.Jens
1992 mazda Miata lowered with Eibach springs KYB AGX adjustable struts Sparco racing buckets 4 point safety harnesses Momo steering wheel lo profile headlite system with PIAA superwhite bulbs Custom audio system Custom gauges Jackson racing supercharger with header and Greddy cat back exhaust and a ton of other stuff 2000 Honda Civic on APEX coilovers Full Alpine Audio system factory fogs with Piaa bulbs Catz ZETA high beam headlamp system H.I.D. Xenon low beam tinted, custom taillites and on and on
Thanks Jens,
Would a Honda dealer have the stuff I need?
Only 3 quarts of fluid? That seems low.
Chris
Chris
<font face="Verdana, Arial" size="2">Originally posted by Chrisbert:
Thanks Jens,
Chris
</font>
Thanks Jens,
Chris
</font>
That is the method I am also asking about. My Bro InLaw said to bring 13 quarts!
Jens, what do you think?
When we service the trans we only use 3 qts as per the service manuals.I have heard of these "forced fluid change" machines but have never seen one in use or have tried one out.In certain cases such as if the wrong fluid was used it is required that the trans be flushed but this is simply done by doing 4 drain and fills in a row.This will require one case of trans fluid.This is really not required unless there is a problem.Jens
SidhuSaaB
05-30-2020 12:40 AM
lanechanger
10-13-2015 10:56 AM
