how to install e brake pads?
So I have original E brake pads on my car which are WORN down and it probably why I barely have a working e brake. I am buying new pads today do the drum set-up.
I have never touched a drum brake can anyone show me or explain to me wtf I'm supposed to do?
You got any pics of that rear brake set up?
dude they are 9 years old.. have been dragged a FEW TIMES, the surface is no longer evenly worn, and there are bumps in it... etc they are TRASH
i just put on new rotors like 8K ago and have not been using the ebrake since it is crap. I've heard on onld rotors the ebrake creates a groove on the inside of the rotor hub and if you change the shoes at that point your will likely only make a problem for yourself. so I would onlt recommend doing this IF your shoes are TOAST/original/abused.. and you have a brand new or fairly new rotors.
Whats up with RDX owners?
The shoes for the e-brake are supposed to drag a bit. The brakes arent supposed to fully disengage, they will always make contact with the rotor/drum.
E-Brake replacements can be a bitch if you don't know how they are setup and if you don't pay attention to where all the small springs go. Also, make sure you follow the proper sprocket adjustment procedure or else they will drag much more than they are suppose to.
If you've never done this before, it will seem like it should be so easy but usually it ends up being harder trying to get the carter pin to line up properly while trying to get the shoes to stay in place.
Make sure you have a steady hand and a good set of needle nose pliers when you tackle this job.
I can understand why you want to try this job though, might as well do it now and get it out of the way.
Also, don't get frustrated with people when you call it a drum setup and they try telling you our car is a 4 wheel disc. You are misleading them when you call them drum brakes.
Blown is Best
I just adjusted mine when I replaced the rear pads and rotors, works good now. There are springs to be removed. I briefly looked at that section in Helms. Let me know if you need any info from Helms.
I guess I didn't explain what part I was talking about, I just always have a problem trying to get the tiny bent end of the spring back into the shoe and that's what always gives me a problem and that's when I am always in need of needle noses and can't find them in my small garage.
As my mom always says, patience is a virtue and I have no patience at all when it comes to frustrating little things like that.
ok bad news I cannot do it today, it's too cold to do it, I got as far as the rotor off and my hands were way too cold after looking at all the intricate work. and I gotta go to see my nono(grandpa) who 30hrs ago went to the hospital and is in ICU.
Blown is Best
You're right Allout, vice grips do work better to hold the pin because it lets you get some force behind it to compress the holder and not have that little bugger slip out.
![](http://www.harborfreight.com/cpi/photos/97800-97899/97804.gif)
Like I said, just make sure you only do one side at a time, or you'll be looking for pictures on line of how all the springs go. I once tore apart all four corners of drums brakes on my 69 Le Mans. That was a nightmare! Wish I had left one for referance.
mada51589
05-03-2022 08:54 PM
