How to get rid of rear progress sway bar SQUEAK??
So over the last few days i noticed a squeak coming from the back of the car (very little but still it's noticible) took off the sway bar bushings and greased them with WHITE LITHIUM GREASE.. but it still is there.
Anyone know how to make sure this lil bitch of a squeak can go away?
Should I use another type of grease?
please let me know. I'm up for any ideas
am i the only one with this issue or what? it's like a little clunk actually ... scrap the squeak comment.
almost sounds like something is loose in the back or something. as if it takes certain bumps hard or something... but when ur driving at normal speeds its not really heard.
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
I have a progress RSB but no noise comming fromit. When I put it on I used the grease that came with it and used the bushings that came with it.. I also Got MOOD sway bar links , did u use the old links or get new ones with the RSB?
Not 4 Wheelin Anymore!
Most likely loose/busted end links but my front poly bushings creak like an old door when going over speed bumps. I am planning on wrapping the sway bar in teflon tape and or putting something under the bushing between the subframe to hold the bushing tighter against the bar. Sorry for thread jacking but I figured I'd throw the last part in there for people with front poly bushings.
Where did you order those from StonedCL? I might need to get some of those also. Thanks.
Blown is Best
Ive been getting the same clunking noise coming from the back. Ive had it checked out by a very good mechanic and he couldn't find anything.
It seems to come and go, usually when im moving at really slow speeds or reversing. I have a CT rear sway that was installed a couple years back. So end links are probably the problem? Teflon tape em?
k i went under there and lithium greased all the pivot points for the rear suspension and greased the hell outta the sway bar bushings and everything is fine again.
I will teflon tape it when we get a day here that is 10degrees or hotter and not raining!..
damn canada has some balz weather
marcelft
07-10-2018 06:17 PM
k6biv
09-10-2015 06:37 PM
