how do you tell you have a bent rim??
PACDAT
How do you tell if you have a bent rim/rims..b/c lately i've noticed a "dug dug dug" type of noise when im cruising at around 40Km/h or lower.. when i go faster.. the noise goes away..
and IF my rims are bent.. what could happen if I keep driving on them?..Thanks
A bent rim is kind of obvious to see.
You may need to take it off the car to see if it’s the INSIDE edge.
Your problem sounds more like a BUBBLE in the tire.
Shawn S
Shawn S
im back
i doubt its the rim because 2 outta my 4 are bent and i've gone 131mph on them and didn't get any vibrations even at low speeds. So check the tires, could be alignment, or lugs
PACDAT
Thanks doods.. bubble in the tire??.. i hope its not that. they only about 3months old..
and i hope its only loose nuts..
This happened after my tires were rotated.. before that it was totally fine.. ill tighten em today..
what happens if you keep driving with bent rims..?
Sounds like cause and effect. Car fine before work, noise after (yes/no?)
Did you have the tires balanced?
PACDAT
i feel it in my gas pedal too(the slight thumping vibration).. on low speeds..and its not my lugs..they were tightly put on..
The car runs perfect..its just at low speeds..it starts to make the sounds and thump thump thump... ?..
what could this be???...
