How do you remove staples that hold on the 03 6MT shift boot?
Old 05-19-2006, 07:26 PM
  #41
fuzzy02CLS's Avatar
Originally Posted by ANDY03CL-S
I also have the Neuspeed Short Shifter adapter and the silver brush peice that goes around the boot keeps popping out of place when I put it into 5th gear. I cant get it to stop. I dont know how your is set up, but I had to shave down the plastic surrounding that holds the boot down so that it would fit. (the part that is stapled to the boot.)
CL6....do you have this problem? If not what did I do wrong and how do I fix it?
And will that Momo boot work with anyother shiftknob?? Cuz I just got the TSX Shift knob and I spent quit a bit of money on it and I do not want it to go to waste. But that is a good looking boot. If it will fit I will have to invest.
Thanks.
Hmm???? I wonder if you guys got the old version of the shift kit somehow? It used to do that & then they changed the design. The 2 I had never had a problem.
Old 05-19-2006, 08:10 PM
  #42
CL6
My only car is a Bus
CL6's Avatar
Old version? I did not know there were 2 versions of the Neuspeed kit.
Old 05-23-2006, 01:48 PM
  #43
Recently turned 18
Blitz's Avatar
Anybody wanna host these pics for me -n- post 'em up?
Old 05-23-2006, 07:21 PM
  #44
CL6
CL6's Avatar
Just use the free one I used.
Old 05-24-2006, 08:13 AM
  #45
"It's sexy time!" (borat)
ANDY03CL-S's Avatar
I had no clue that they had 2 different versions but I dont care it is what it is. And I gotta fix it. Double sided tape was a good idea. Thanks.
Old 05-24-2006, 02:56 PM
  #46
Recently turned 18
Blitz's Avatar
The first is the example of what is done to my shift boot.
The second and third are the shift boot I'd like to get rid of.
Old 05-24-2006, 04:55 PM
  #47
CL6
CL6's Avatar
Looks like a pretty good solution.
Old 05-26-2006, 04:11 PM
  #48
Recently turned 18
Blitz's Avatar
Perforated shift boot now being sold in Black Market.
Old 05-27-2006, 06:38 PM
  #49
IHmike345's Avatar
OK.. I just installed a Momo Race AirLeather Shift knob with a Endurance shift boot (short) and the Endurance finisher ring. Here are a couple of notes that should be helpful to anyone changing the shift boot and knob.
1. The staples suck... what a stupid way for Acura to install this thing... WTF!!! Do NOT use an industrial staple gun as someone suggested. This is how I broke the white plastic piece that goes under the shift knob/gray plastic plate assembly. Now the dumbass assembly pops out of place sometimes when I shift. I bought some double sided tape today to solve that problem!
I used Super Glue designed for leather and plastic instead of the staples. This has held for about 3 months now. Screw the staples! I am not saying it cant be done properly, but your asking for trouble if you go this route!
If you break the white plastic part, you have to buy the whole shift boot assembly... and it is fecking expensive to get just that piece (>$138).
2. To use the Endurance boot and finisher ring, you have to file out the inside of the finisher ring to make it fit over the "bend" in the shifter. Not a big deal... but just good to know ahead of time(especially if you are allready super frustrated cause you just broke that white plastic piece of crap! )
3. This setup looks awesome, once you get it installed right. I know this post is useless without pics, but I dont have my camera anymore. And anyway, if you guys saw how good it looked you would just copy it!
4. I didnt realize how bad the stock knob sucked until I replaced it. If you havent allready, change it up! The Momo shift knob with Endurance boot and finisher ring is P*I*M*P. You wont be dissapointed!
Old 05-28-2006, 02:14 PM
  #50
CL6
CL6's Avatar
Good write up. The double sided tape is crucial. Originally Acura used some kind of silicone type sealer to go around the boot. The only problem I have with my Momo knob is held tight with three little tiny screws and they work their way loose eventually. I wrapped the top of the shift lever in electrical tape. The I put the shift knob on top of that and tightened down the screws, which 'bite' into the soft tape and seem to hold it tighter longer.
The CL shift knob is the same as the Prelude and the NSX and I always thought it was was too tall. Get a short shift adaptor from Neuspeed too. That and a shorter Momo knob is awesome.
Old 05-29-2006, 10:01 AM
  #51
IHmike345's Avatar
Didn't your Momo shift knob come with varios sized little black rubber things that go over the metal top of the shift lever? Mine came with a bunch of these and you find the correct size and put it on before the shift knob. This helps to hold it in place.
I have been worried about the shift knob coming loose, but so far so good. Did you alternate tightening the 3 screws, so that you are tightening each one a little bit at a time?
Old 05-29-2006, 03:06 PM
  #52
CLS6SpeedNupe's Avatar
i was about to order a accord V6 6 speed shift knob to replace mines and thought it would be a easy task but i guess i thought wrong
Old 05-29-2006, 04:11 PM
  #53
Recently turned 18
Blitz's Avatar
It is easy.
Old 05-29-2006, 05:46 PM
  #54
CL6
CL6's Avatar
Yeah the rubber things. That got chewed up pretty quick. Use the electrical tape and the rubber thing. I tightened the screws one at a time. They do work themselves loose, but it takes 4-6 months for mine. Still, I prefer that over the stock knob.
Old 05-31-2006, 03:40 PM
  #55
CLS 6MT Navi
123456SPEED's Avatar
I just saw on the Acura site, under used models, it says the 03 CLS 6MT has
'Leather shift boot (manual transmission only)'.
It sure doesn't feel, look, or smell like leather? Must have changed to poly?
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
marcelft
07-10-2018 06:17 PM
lland
10-04-2015 04:47 PM
CaliBud916
09-19-2015 01:56 PM
Quick Reply: How do you remove staples that hold on the 03 6MT shift boot?
