How do I get the back seat out?
Old Feb 3, 2001 | 02:55 PM
4pumpedCL's Avatar
Honkey
how do I get the back seat out to access the top of the rear spring/shock assembly?
Aaron
www.artofnoize.com
Old Feb 3, 2001 | 04:39 PM
fender4's Avatar
1) remove 2 lower bum seats by pulling up on front of seat (strong straight up pull)
2) remove four bolts holding rear console, remove console.
3) remove two bolts one each side of back seat, near belt retractor. reomove seat back by lefting straight up two or three inches, then remove seat back. Note very hard to keep seats clean while doing this.
You can then access shock towers without removing back speaker tray . good luck
You should buy a Helms repair manual, it has all the details needed for these type of jobs. :0
Old Feb 3, 2001 | 10:45 PM
4pumpedCL's Avatar
Honkey
okay...I'm stuck on step number one. I tried pulling up on the bottom seat, but nothing is happening. Should I pull harder? Are there any bolts that hold the bottom portion of the seat in? Thanks again.
Aaron
www.artofnoize.com
Old Feb 4, 2001 | 12:26 AM
fender4's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 4pumpedCL:
Aaron
www.artofnoize.com
</font>
PULL HARDER EACH CORNER, you'll feel a little give. no bolts
Old Aug 13, 2003 | 12:53 AM
4pumpedCL's Avatar
Honkey
Just wanted to let you guys know I was able to get the seat out. Thanks for all the info.
-Aaron
Old Aug 13, 2003 | 12:57 AM
bullaculla's Avatar
-Aaron
WOW! only took 2 years!
Old Aug 13, 2003 | 01:02 AM
AztecRol's Avatar
The Screeching Toyo's
-Aaron
THANKS FOR KEEPING US UPDATED!!!!!!:P :P
Old Aug 13, 2003 | 01:43 AM
mattg's Avatar
lolz
Old Aug 13, 2003 | 02:10 AM
kHmER Co's Avatar
mister D
-Aaron
02-03-2001 03:55 PM lol. crazy.
Old Aug 13, 2003 | 06:22 AM
mantis23's Avatar
Moderator Alumnus
can someone post a DiY please?
Old Aug 13, 2003 | 06:51 AM
JRock's Avatar
Old timer
Awesome thread
Old Aug 13, 2003 | 07:49 AM
gsrblack's Avatar
I think we have closure now....
Old Aug 13, 2003 | 09:29 AM
SilverKnight's Avatar
Retired. Not available.
LOL. This is worse than Amir's 11 hrs CAI installation.
Old Aug 13, 2003 | 11:49 AM
fender4's Avatar
I'm still looking at his aviator
Old Aug 13, 2003 | 12:04 PM
Red-CL's Avatar
Doin' da crack shuffle
so am I.
Old Aug 13, 2003 | 12:05 PM
mantis23's Avatar
Moderator Alumnus
whats an aviator?
Old Aug 13, 2003 | 12:10 PM
6mt's Avatar
6mt
-Aaron
<< on the floor, laughing my a$$ off
Old Aug 13, 2003 | 12:16 PM
mattg's Avatar
Originally posted by mantis23
whats an aviator?
someone who flies a plane.
Old Aug 13, 2003 | 12:17 PM
AgentDSS's Avatar
Black is a ***** to Clean
I have a real ques....I had removed my rear seat bottom cushion (after using a lot of force i might add!) and when i tried to put the cushion back on, i tried to line up those two clips and push down on the seats, but only one side "locks" into the clip hole (but no where near the secureness of when the seat was first removed) and the other clip just fits in the hole w/o locking.
umm.. help
Old Aug 13, 2003 | 12:38 PM
mattg's Avatar
you may need to replace the clip.
those clips will never be as tight after being popped in and out of a few times.
Old Aug 13, 2003 | 12:40 PM
darrinb's Avatar
///M POWER
i took apart my back seat when i got the sprimgs put on but i couldnt put it back together
Old Aug 14, 2003 | 01:12 AM
bullaculla's Avatar
the guys that did my timt fuct up my "clip holes"
I got them back in, but when i pull the seat out now, the clip hole comes out and is stuck to the metal clip. I need a new one.
Old Aug 14, 2003 | 06:13 AM
bullaculla's Avatar
:edit:
the guys that did my tint fuct up my "clip holes"
Old Aug 14, 2003 | 01:13 PM
MtBikR's Avatar
Glad to hear that everything got worked out Aaron, now that you've got that rear seat out, do you plan on running pumps?
Old Aug 14, 2003 | 01:24 PM
runnerX's Avatar
not sure if it is already too late...
Guys, don't pull too hard on the seats, cuz it will deform the cushions. The Acura mechanic deformed my back seat cushions when doing the rear deck rattle check, luckily they replaced them under warranty.
Old Aug 14, 2003 | 01:31 PM
mantis23's Avatar
Moderator Alumnus
replace clips with clits and it works just the same.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
d.lim
Sep 15, 2015 08:54 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
