How do I change a Xenon Bulb??
Old Jun 16, 2006 | 02:36 PM
q7suited's Avatar
No one really answered my question in my other post, so Mods please do not delete??
I have no Idea on how I change a XENON bulb?? Are they replaceable whn they burn out??
I have never had XENON light before so i am new to this, please let me know, and do I need to remove the entire headlight housing to replace the bulb??
And do i need to remove the front bumper cover to remove the Headlight housing??
Old Jun 16, 2006 | 02:42 PM
MarbleGT's Avatar
'08 MX5 GT 6spd.
Just change it like a normal bulb.
Get a small flathead, unscrew the cap. Next there will be a metal clip you need to unclip. Twist the bulb and it will come out.
Old Jun 16, 2006 | 03:00 PM
Lord Helmet's Avatar
I'm here in spirit...
The only thing... the only thing is taking off the cover for the bulb. It has some kind of security screw in it. But like o2 said, a small (tiny) flathead screwdriver will work. That's what I used when I did my headlight mod and if worked fine.
Old Jun 16, 2006 | 03:23 PM
MISTAZOOM's Avatar
2003 CL-S 6SPD
What about types of bulbs? Going to the dealership is good enough? Or are they other types of xeons that one should be looking at? Just for some future notes.
Old Jun 16, 2006 | 04:26 PM
phipark's Avatar
Not Asian
Types of bulbs? As in brand or color?
Old Jun 16, 2006 | 06:35 PM
MISTAZOOM's Avatar
2003 CL-S 6SPD
Sorry, types and if there are different brightness or such. I thought i seen a thread on here before that talked about different types of bulbs and what we should be using. Unfortunately i cannot locate it...
MarbleGT's Avatar
'08 MX5 GT 6spd.
bulb type - D2R STOCK-4300k
Unfrotunatly buying 1 bulb will nto always match your existing bulb. You are better off buying both which will set you out mroe than $200 bucks.
Old Jun 16, 2006 | 06:43 PM
MISTAZOOM's Avatar
2003 CL-S 6SPD
Thats harsh... /me rubs lights and prays!
Old Jun 17, 2006 | 02:38 AM
q7suited's Avatar
but on the cap theres a sticker that says do not remove because of high voltage??? Should I disconnect the battery before doing so??
So I do not need to remove my headlight housing?
Old Jun 17, 2006 | 12:43 PM
bojingle's Avatar
I didn't disconnect my battery, I just didn't touch the wires when I was pulling it away from the bulb. In your case, I would because some idiot might think its funny and turn on your light switch while your working on it. (anyone know if there is a capacitor held in the charge after power is disconnected?)
no, you don't need to take out the housing. Just pull out the stuff directly behind the cap. It took me about an hour because I didn't know what I was doing and I couldn't find the right tools.
pplcrew
Jan 30, 2021 08:59 AM
BoricuaTL
Apr 8, 2016 01:08 PM
Sep 17, 2015 09:01 PM
Aleax
Sep 11, 2015 11:31 AM
voigt
Sep 2, 2015 10:44 PM
