How to Access Drivers Side HID Bulb?
Old Dec 16, 2008 | 02:40 PM
bateman's Avatar
I have taken a long look under the hood to get an idea on how to remove the HID bulbs in my 03' CLS in order to troubleshoot a likely dead bulb (and replace if it is the bulb). The passenger side seems rather simple to access but I can't seem to figure out how to access the driver side bulb as the black cylindrical cover is surrounded by other parts/equipment making it so I can barely see it, much less get in there with a hand and torx bit.
From my search around the forum I get the impression that it is somewhat simple to change out the HID bulbs without removing the bumper but I seem to be missing something. Is there one particular item(s) to remove in order to pull the driver side bulb?
Thanks.
Old Dec 16, 2008 | 03:31 PM
gnuts's Avatar
3.5 psi
The torx screw is right there facing upwards on the drivers side i thought. I swapped bulbs before to check if i had a bad ballast or bulb and i never had to take the bumper off. It should just be the torx screw on the circular cover...it has a warning on it about electricuting you to death.
Old Dec 17, 2008 | 02:09 PM
bateman's Avatar
Thanks. I have located the torx screw so hopefully I can remove some of the plastic casing around that area to free things up.
Old Dec 17, 2008 | 02:36 PM
fuzzy02CLS's Avatar
You can remove the white plastic coolant bottle. It just slide up off the bracket. That will give you a little room.
Old Dec 17, 2008 | 03:15 PM
02CLNOS's Avatar
take out to air box, then take the rad. sheild off and then their is a little divider around the lamp, pop that off and take the overflow bodle out.... like fuzzy said and then you have access to the screw and the room to remove the cap
Old Dec 17, 2008 | 03:36 PM
bateman's Avatar
Thanks everyone. That was just the info I was looking for.
rockyboy
Aug 4, 2024 10:35 AM
oo7spy
Jun 19, 2023 12:48 AM
sockr1
Oct 1, 2015 01:31 AM
acuraST
Sep 17, 2015 02:31 AM
JnC
Sep 11, 2015 06:06 AM
