Hood release cable broke...
2003 CL-S
The hood is closed and the cable is broken. Anyone here been is the same predicament?
How can I pop the hood without the cable and if anyone has replaced the cable would love some tips
Thanks in advance!
Thanks in advance!
Hmm do you know what part of cable is broken?
Removed my cable and hood latch recently and installed hood pins.
Cable goes behind driver headlight and through the fender on drivers side.
If it broke where the interior release is then it should be rather easy. Just find the cable, cut away outside layer to get to metal cable , then pull metal with pliers to release.
Check the release in the driver's compartment, it may of came off at the release handle.
Otherwise you'll have to come from under neath the bumper by removing the lower baffles.
Thanks for the replies guys. This community is pretty good. Takes forever to get answers on other forums. Kudos.
I will have to see if I can tug on the cable without opening the hood.
If the cable broke off at the latch, sounds like it's going to be a real pita to get the hood to pop.
polish_pat
19
12-03-2015 07:38 PM
alynjewels
10-24-2015 11:07 AM
4drviper
10-13-2015 05:06 PM
