Cold air intake worthi it? Also how difficult is it?
Old Feb 25, 2015 | 07:39 PM
maxguitars's Avatar
I am looking to bypass/junk the airbox in favor of a cold air set up. Is this a difficult mod for a novice? What results can I expect?
Thanks all
Old Feb 25, 2015 | 08:39 PM
gnuts's Avatar
3.5 psi
Vtec will sound better, that's about it. It's pretty easy to install. Is this your first mod?
Old Feb 25, 2015 | 10:36 PM
Ponto's Avatar
It was my first mod and it was very easy. I think it's worth it and I read anywhere from a few to 15 ponies. I thought there was a dyno that saw a 10hp bump but who knows. The sound is great and I felt slightly better throttle response.
Old Feb 26, 2015 | 01:15 AM
maxguitars's Avatar
This is my first mod. Aside from changing oil and the occasional tire I am a novice. What should I buy? How many steps roughly?
Old Feb 26, 2015 | 07:59 AM
gnuts's Avatar
3.5 psi
if you're looking for power, then get headers before anything. Are you auto or manual?
Old Feb 26, 2015 | 08:34 AM
coopcoop30's Avatar
I agree with gnuts.......If however you can find a Comptech Icebox CAI that would be the way to.
Old Feb 26, 2015 | 11:59 AM
YeuEmMaiMai's Avatar
car already has a cold air intake. just remove the resonator from driver's side fender....
Old Mar 11, 2015 | 03:02 PM
Silver℗'s Avatar
How much is a 5% HP boost worth to you? Not enough to feel but it does make the engine more aggressive.
Install is not a problem if you are mechanically inclined.
Old Mar 11, 2015 | 06:58 PM
mike88se's Avatar
5%? If I thought I'd get 13hp I'd have installed mine already
Old Mar 12, 2015 | 04:26 PM
ExcelerateRep's Avatar
Former Sponsor
Intake install is straight forward. I'd recommend a cold air as they will provide the best gains. The AEM Intake is a great option. We have it listed on our website for $271.69:
AEM Cold Air Intake - Excelerate Performance - Japanese and European Performance Specialists!!
Old Mar 12, 2015 | 08:29 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
Intake was my first mod. and it made a difference. You could clearly hear vtec kick in! And it liked to rev higher. You could tell it made more power up high.
I know some will argue it's all in ur head. But hey that's what my head thinks lol.
Old Mar 12, 2015 | 10:51 PM
DaFunk_80's Avatar
Are you referring to exhaust headers?
Old Mar 13, 2015 | 06:23 AM
^yes, it is the absolutely best bang for your $$ in terms of HP/$
Old Mar 15, 2015 | 08:48 PM
Rapture's Avatar
My CAI was also my first mod ever (not just with this car) and it was pretty simple. I tend to be overly cautious and strict about making sure everything is set up 100%, so it took me awhile to get it done, but overall it wasn't too difficult.
fwiw my CAI is an Injen. afaik it has the same setup as the AEM V2 where you have to do a coolant bypass and whatnot. If you get an AEM make sure it has a rubber mount so it won't break from engine vibrations. Assuming AEM still makes and sells the ones that don't...
Old Oct 15, 2015 | 03:18 AM
mike88se's Avatar
I finally installed mine today. I had to take the bumper off to reseal a head light housing and it seemed like a perfect opportunity. And... the damned thing didn't fit Actually it did fit but the bracket that attaches the pipe to that anti-vibration mount is off by about an inch or 2. It's an Injen 1660B
Old Oct 15, 2015 | 12:21 PM
brian6speed's Avatar
Lone Wolf
I am not impressed with any off the shelf intakes for CL. Comptech is a nice design, but tubing is too small and restrictive.
Custom is the way to go on almost everything.
Old Oct 15, 2015 | 03:08 PM
mike88se's Avatar
Based on my experience I totally agree. Piping/tubing is pretty much the same across the board. Some filters are better than others... custom gives you the choice. And I have to say again after actually seeing the stock intake... it's a good design. The only upside I see here is the smooth piping vs the convoluted rubber stock parts. You still get that benefit with custom. And for a lot less money.
And I'm still going to be doing extra work fabbing up a bracket to attach to that Injen bracket lol
Old Oct 16, 2015 | 04:32 AM
Rapture's Avatar
Mine is an Injen RD1481. According to the Injen website, both part numbers work... why would they have two different parts?
Old Oct 17, 2015 | 08:38 PM
mike88se's Avatar
I could have sworn I responded to this
From another thread
Originally Posted by fsttyms1
CL has a smaller tb than the CL-S. CL-S Auto cai is shorter than the CL due to the VSA TB that the CL doesnt have. CL-S 6 speed is different than the CL-S Auto. If you have an automatic you can use the one for the TL-S as well.
Old Oct 17, 2015 | 09:27 PM
mike88se's Avatar
This is how I attached the tubing to the body. No big deal but it shouldn't have been necessary.
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
jmaxima03
Sep 27, 2015 10:22 AM
