Honda interlock repairs exceed 1 million
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
![Thumbs Down](https://acurazine.com/forums/images/smilies/thumbsdown.gif)
defect that can allow them to roll away when they are parked.
The cars were built for the 1997-2002 model years. The automaker conducted a
similar repair of nearly 600,000 other Honda and Acura vehicles in late
2003. In both cases a flaw in the ignition interlock system allows a driver
to remove the key when the transmission is not in park. The rollaway danger
occurs when a motorist leaves the vehicle without
shifting into park or applying the emergency brake, the National Highway
Traffic Safety Administration says.
The recall involves some 1999-2002 Honda Accords, 1997-2001 Honda Preludes
and 1999-2000 Acura TLs.
Honda told NHTSA it believes the defect has developed in less than 0.05
percent of the recalled vehicles, or 250 cars. But it is installing an
improved interlock lever in all of them, the automaker says. There is no way
to predict which cars will fail, said William Willen, managing counsel in
Honda's regulatory office.
Honda plans an additional repair of those cars that already have had an
interlock failure. The automaker says it has not defined that repair.
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
Documents on file with NHTSA show the recall covers only vehicles with
interlocks from an unidentified Japanese supplier. Cars with parts from a
U.S. supplier do not appear defective.
The earlier recall involved some 1998-99 Honda Accords and Acura CLs and
1999 Honda Odysseys and Acura TLs.
Doin' da crack shuffle
Seems a bit backwards doesn't it?
![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
About 2 years ago I had a car wash place somehow remove my key with the car in drive. It didn't roll or anything, but I was bewildered when they handed me the key and I went into the car only to discover it was in drive! Morons - needless to say I never went back there again.
About 250 cars or .05% and that promps a recall but not the transmission problem
Originally Posted by mt6forlife
If you leave the car without putting it in park or having the parking brake on, you deserve to have your car run away and hit a wall.
i wish honda would just smartin up, dont they know this kills there fan base. i love my cl but i doubt i'd get another one, its great but my gm never had so many issues, i guess thats just life.
![Lightbulb](https://acurazine.com/forums/images/icons/icon3.gif)
in most cases i guess if you jumped out to say run to a store while your double parked or something that cause u 2 not pay attention while placing the shifter in park, i could c this happening, a.t. cls r the ones with this problem and u would assume its in park if u shift 2 park and pull the key. big mistake ![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
Boomer SOONER
Don't Mess With Texas
Originally Posted by ou sig
are you kidding!? If your GM has had less issues its a stroke of luck for you - I believe American cars have came a very long way, but there is no way I would choose a Chevy sedan over an Acura on reliability issues.
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
I guess you'd have to be pretty inexperienced to do that. When I get in or out of a car, I have a routine I do without thinking. When I drove an auto, part of that was putting the car in park and then releasing the brakes and then removing the key. Park is the highest position too. Push it till it stops. Not too hard. Oh well, people who can't operate machines are the reason lawyers exist.
i agree but no one was born a perfect driver, and with such flaws like the interlock ;lawsuits, lawyers, and recalls exist.
Originally Posted by mrsteve
Oh Christ, all cars get recalled for one thing or another. What's the big deal? Quit bitching.
General Recalls and TSBs for the Acura CL-S:
General Recalls and TSBs for Chevy Malibu:
Safety Recalls
'nuff said
TSB Number Issue Date TSB Title
1. 03-030 OCT 03 Campaign - Engine Timing Belt Tensioner Replacement
2. 03-017 SEP 03 Campaign - PCM/Fuel Pressure Regulator Update
Service Bulletins
1. 04-008 MAR 04 Navigation System - Operational Malfunctions
2. 01-041 FEB 04 Engine - V6 Engine Oil Leaks
3. 04-004 FEB 04 Computers/Controls - HIM Module Updating
4. 01-026 JAN 04 Engine Controls - ECM/PCM Reprogramming
5. 00-037 OCT 03 Brakes - Brake Disc Refinishing Guideline
6. 03-029 OCT 03 Brakes - Brake System Lamp Comes ON/Goes Off
7. 03-028 OCT 03 Navigation System - Incorrectly Displays Phone Numbers
8. 91-050 SEP 03 Interior - Seat Belt(s) Slow to Retract
9. 03-015 AUG 03 Audio System - Remote Controls Don't Work Properly
10. 98-005 JUL 03 Drivetrain - Revised CV Joint Boot Band/Installation
11. 97-040 MAY 03 Keyless Entry - Description/Identification/Programming
12. 01-017 MAY 03 Brakes - Pedal/Steering Wheel Vibrate When Braking
13. 00-019 APR 03 Antitheft System - Type 2 System Operation/Programming
14. 03-010 MAR 03 Engine Controls/Emissions - DTC's & Monitors
15. 03-006 MAR 03 Engine Controls - Idle Speed Inspection
16. 03-003 FEB 03 Interior - Power Seat Rail Synchronization Update
17. 03-001 JAN 03 Emissions - MIL ON/DTC P1457 (EVAP) Set
18. 02-020 AUG 02 Air Bag System - Occupant Position Sensor Initialization
19. 02-015 JUL 02 Air Bag System - SRS Lamp ON/DTC's Set
20. 02-012 MAY 02 Clutch Master Cylinder - Fluid Leakage
21. 02-006 MAR 02 Front Seat Back Panel - Loose/Detached
22. 02-005 FEB 02 Emissions - EVAP System Testing and Diagnostics
23. 96-025 DEC 01 Navigation System - Component Exchange Program
24. 99-041 NOV 01 Navigation System/A/C - Operation/Testing
Service Bulletins
Safety Recalls
1. 02015 MAY 02 Recall - Headlamp Inspection/Replacement
Service Bulletins
1. 00-00-89-008D APR 04 Vehicle - Recreational Dinghy Towing
2. 04-06-04-024 APR 04 Engine Controls - Poor Generic SCAN Tool Communication
3. 04-06-01-013 APR 04 Engine - Serpentine Drive Belt Wear Information
4. 04-07-30-013 MAR 04 Air Filter - SES Lamp ON/Multiple Driveability Concerns
5. 01-07-30-036C MAR 04 A/T - DTC P0756 Diagnostic Tips
6. 00-06-02-006A FEB 04 Cooling System - Coolant Information
7. 02-07-30-001A FEB 04 A/T - 4L60E and 4L65E DTC P0894/P1870 Diagnostics
8. 04-07-30-006 FEB 04 A/T - 4L65E, 4L60E, 4L60, 200-4R Oil Pump Spring
9. 01-08-64-020B FEB 04 Body - Doors Creak When Opening or Closing
10. 01-07-30-038B JAN 04 A/T - 4L60-E/4L65-E MIL ON/DTC P0757/Slipping
11. 04-08-48-001 JAN 04 A/C - Broken Defogger Grid Detection
12. 02-06-05-004A JAN 04 Emissions - Catalytic Converter Damage/Misfire Codes Set
13. 04-01-37-001 JAN 04 A/C - Control Knob Replacement Availability
14. 04-03-10-001 JAN 04 Tires - Puncture Repair Guidelines/Procedures
15. 02-08-48-001A DEC 03 Windows/Glass - Urethane Adhesive Usage
16. 03-07-30-021A NOV 03 A/T - Shift Flare/DTC's Set/SES Lamp ON
17. 01-08-42-001A NOV 03 Lighting - Lamp Condensation/Replacement Guidelines
18. 01-01-38-013A OCT 03 A/C - Unnecessary Compressor Replacement
19. 03-02-32-049 OCT 03 Steering - New Outer Tie Rods/Replacement Procedure
20. 03-06-01-010B OCT 03 Engine - Intake Manifold Oil/Coolant Leak
21. 99-09-40-005A OCT 03 Interior - Seat Belt Extenders
22. 02-07-30-022B OCT 03 A/T - MIL/SES Lamp ON/Multiple A/T DTC's Set
23. 03-07-30-012A OCT 03 A/T - Slips/Won't Shift/Erratic Shifting
24. 03-09-41-003 JUL 03 Restraint System - Proper Air Bag System Diagnosis
25. 01-06-01-011A JUL 03 Engine - Oil Consumption Information
26. 01-01-39-003A JUL 03 A/C - Catastrophic Compressor Failure Debris Removal
27. 01-01-38-006B JUL 03 A/C - R-134A System Flushing Procedure
28. 03-07-30-027 JUN 03 A/T - Oil Cooler Flushing Frequently Asked Questions
29. 03-06-04-030 MAY 03 Fuel System - Possible MIL ON/Driveability Symptoms
30. 99-08-52-005A MAY 03 Keyless Entry System - Operational Characteristics
31. 01-06-04-008D APR 03 Fuel System - Inaccurate Fuel Gauge Readings
32. 03-07-29-004 APR 03 M/T - Operating Characteristics
33. 01-03-08-002B APR 03 Suspension - Front Suspension Clunk/Rattle Noise
34. 99-01-39-007B MAR 03 A/C - Automatic A/C Functional Description
35. 03-01-38-001 MAR 03 A/C - System Sealers/Leak Detection Guidelines
36. 03-07-30-006 MAR 03 A/T - 4T40-E/4T45-T Engineering Changes
37. 01-05-23-001A MAR 03 Brakes - Brake Rotor Lateral Runout Correction
38. 00-05-23-002B MAR 03 Brakes - Front Disc Brake Pulsation
39. 03-04-18-002 MAR 03 Drivetrain - Revised Wheel Drive Shaft Replacement
40. 02-08-42-001A MAR 03 Lighting - Polycarbonate Headlamp Damage Prevention
41. 02-07-30-052B FEB 03 A/T - Oil Cooler Flushing Tool/Procedure
42. 99-07-30-017A FEB 03 A/T - Oil Cooler Flushing/Flow Check Procedures
43. 03-04-18-001 FEB 03 Drive Axles - Improved Axle Nut Availability
44. 03-06-01-002 FEB 03 Engine - New Polymer Coated Piston and Rod Assembly
45. 99-08-64-016A JAN 03 Body - Weatherstrip Maintenance
46. 03-06-04-012 JAN 03 Electrical - Wiring Harness Inspection Recommendations
47. 02-07-30-050 DEC 02 A/T - 4T45E Engineering Changes/Overhaul Revisions
48. 99-07-30-030B DEC 02 A/T - Grinding/Growling While in PARK on an Incline
49. 02-06-03-006A DEC 02 Electrical - Testing Before Replacing Battery or Alt
50. 02-07-30-048 NOV 02 A/T - Pressure Control Solenoid Replacement
51. 02-06-03-010 OCT 02 Battery - Parasitic Drain Information
52. 02-06-01-034 OCT 02 Engine - Rocker Arm Bolt Tightening Specification Update
53. 02-07-30-022A SEP 02 Transmission Controls - SES Lamp ON/ DTC's Set
54. 02-08-66-005A AUG 02 Body - Rear Compartment Molding Loose/Broken
55. 02-06-03-008 AUG 02 Charging System - Low Voltage Display ON/Dim Lights
56. 02-06-01-028 AUG 02 Engine - Crankcase Flushing Recommendations
57. 02-08-47-001 JUL 02 Body Control - Update of Some Control Module DTC's
58. 00-08-42-007A JUL 02 Stop/Tail Lamps - Inoperative/Water Inside Lamp
59. 02-07-30-028 JUN 02 A/T - Serial Number/Site Code Locations/Identification
60. 02-09-41-001 JUN 02 Computers & Controls - DTC's Set When Replacing Modules
61. 02-06-01-026 JUN 02 Engine - Identification Information
62. 02-06-03-005 JUN 02 Engine Controls - MIL ON/Multiple DTC's Set
63. 02-08-44-007 MAY 02 Audio System (XM) - Negative Impact of Vinyl/Cloth Roofs
64. 02-07-30-021 MAY 02 Engine Controls - SES Lamp ON/TCC Inoperative
65. 02-08-49-002 MAY 02 Instrument Panel - Rattle/Itching Noise
66. 02-08-46-007 MAY 02 OnStar (R) - Caller Minutes Cannot Be Replenished
67. 02-08-46-006 MAY 02 OnStar (R) - Incorrect GPS Location During OnStar Call
68. 02-08-42-004 APR 02 A/T - PRNDL Display Dim for One Minute
69. 01-08-57-007A APR 02 Body - Water Leaks to Interior/Trunk
70. 02-05-22-001 APR 02 Brakes - Revised Specifications
71. 02-06-01-014 APR 02 Intake Manifold (Lower) - Revised Installation
72. 02-08-46-004 APR 02 OnStar System (R) - Cellular Error Messages
73. 99-08-51-007A MAR 02 Aluminum Wheels - Refinishing
74. 02-06-04-015 MAR 02 Engine - Intermittent No Crank/No Start
75. 02-06-01-008 MAR 02 Engine - New Prelube Tool
76. 02-03-08-003 FEB 02 Suspension (Front) - Revised Torque Specifications
77. 01-03-08-003A FEB 02 Suspension - Front/Rear Squawking Noise
78. 99-00-89-019B FEB 02 Warranty - Parts Return Program Explained
79. 02-06-01-003 JAN 02 Cylinder Head - Torque Sequence/Specification Revision
80. 00-00-89-027A JAN 02 Interior - New Odor Elimination Product
81. 02-08-116-001 JAN 02 PCM - Intermittent Communication or DTC Codes Stored
82. 01-03-10-012 JAN 02 Wheel Balance/Alignment - Labor Operation Guidelines
83. 01-07-30-039 DEC 01 A/T - 4T40E or 4T45E Changes for 2002
84. 01-07-30-041 DEC 01 A/T - Fluid Leak Diagnosis
85. 01-08-49-020 DEC 01 Ignition Lock Cylinder/Switch - Replacement Revision
86. 01-08-46-006A DEC 01 Onstar(R) - Antenna Coupling Revised Procedures
87. 01-03-10-011 DEC 01 Tires - Sidewall Damage
88. 01-08-49-016 NOV 01 Cigarette Lighter - Inoperative
89. 01-08-97-002 NOV 01 HomeLink(R) Transmitter - Programming Difficulties
90. 01-07-31-002 NOV 01 M/T - Improved Clutch Bleeding Procedure
91. 01-03-10-009 NOV 01 Wheel Nut Covers - Loose/Missing
92. 01-07-30-029 OCT 01 A/T - Core Return Product Feedback Form
93. 01-08-44-011 OCT 01 CD Player - CD Cannot Be Inserted or Ejected
94. 00-06-04-011A OCT 01 EVAP System - Monitor Strategy
95. 01-08-51-003 OCT 01 Vehicle - Interior/Exterior Anti-Corrosion Materials
96. 01-00-89-013 SEP 01 RKE Transmitter - Correct Use of Labor Operation R4490
97. 01-08-46-004 AUG 01 Cellular Phones - Operating Characteristics
98. 01-08-51-002 AUG 01 Door Edge - New Protection
99. 01-01-38-006A JUL 01 A/C - Proper Flushing Procedures
100. 01-00-89-010 JUN 01 Diagnostic Worksheet - Usage
101. 99-06-03-010A JUN 01 PCM/BCM Replacement - DTC's B001/B1271/B1780 Set
102. 01-09-40-002 JUN 01 Seat Belt System - Collision Replacement Guidelines
103. 99-01-39-004A MAY 01 A/C - Odor Emission in Hot Weather
104. 01-00-89-009 MAY 01 Key/Key Number/Security Chip - Replacement
Service Bulletins
'nuff said
What does money have anything to do with this? Its a free service
![n00b](https://acurazine.com/forums/images/smilies/n00b.gif)
but u got me
![Patriot](https://acurazine.com/forums/images/smilies/patriot.gif)
![Rock On](https://acurazine.com/forums/images/smilies/rockon.gif)
lanechanger
10-13-2015 10:56 AM
