Hid Problem
Old Jun 13, 2008 | 11:34 AM
LUTHOR-CL's Avatar
Chapter Leader (NY/NJ)
Hid Problem
my pass headlight went out w/out flickering, there wasnt any change of colors that would have indicated the bulb dying.
so we pulled the pass bulb out and then i bought a new pair of hid and installed them. and it wwas working.
but then few hrs later that blows out again(only the pass side). i didnt even use it as much.
what could it be the ballast or fuse, should i work on the fuse first? then see if the ballast is bad? (hope its not the ballast) coz it worked for a few then later on it dies out, i dont kno what to do now. tried searching but so far i havent read any that had the same problem as mines, mine worked when i installed the new ones then it died afterwards, their new as well.
it wouldnt have to do w/ anything from when my mechanic changed my front radiator right, like he accidentally diffused something or whatever?
thanx
Old Jun 13, 2008 | 11:53 AM
fuzzy02CLS's Avatar
I vote bad Ballast
LUTHOR-CL's Avatar
whats the warranty on the ballast?
Old Jun 13, 2008 | 01:54 PM
colemab's Avatar
03 3.2 CL Type-S (AT)
some threads about the HIDS:
https://acurazine.com/forums/showthread.php?t=195200
https://acurazine.com/forums/showthr...hlight=ballast
https://acurazine.com/forums/showthr...dlight+removal
Old Jun 13, 2008 | 01:56 PM
fuzzy02CLS's Avatar
If you car has warranty it should be covered.
Old Jun 13, 2008 | 02:24 PM
ljmushock's Avatar
yeah prolly the ballast, just picked mine up today!
Old Jun 13, 2008 | 08:06 PM
CL6's Avatar
CL6
My only car is a Bus
CPO doesn't cover the ballast. I bought one online for a few hundred easy to install just make sure you have the Torx for getting the ballast off.
Old Jun 13, 2008 | 09:45 PM
LUTHOR-CL's Avatar
ok its the ballast, so i got one for $40 aftermarket ballast.
now how do i install?
does it require to tkae off the headlight therefore taking off the bumper as well?
anyone has any pix? thanks
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
