hid lights?
7th Gear
hid lights?
hi i saw on a website that there are d2r 6000 k and d2r 8000k i know that the 6000 k will fit on my cl but will the 8000k ones fit on there? and i want a look that will look purple or more blue so which bulb will be better? and what i sthe current k's on the stock bulbs on our cars?
Originally posted by CLpower
the 8000K and 6000K just represent the coloring from what I understand as long as it's a d2r you should be alright.
Keep in mind that the higher you go on temp, the lower the light output is. I believe the stocks are around 4200k, so personally I wouldn't go over 6000k as the 8000k are more for looks and less for actually lighting the way.....
AWD Torque Monster
the only true 6000k bulb is the philips ultinons. anything else is coated and usually a cheap brand. at least make sure they are philips or osram bulbs if they are coated. personally i would just put philips d2s bulbs in. they will be brighter becuase there is no black coating on them. are you going for looks or light output?
7th Gear
there on plasmagarage.com but they said its the same thing as philps and they have the sam eligth output as them but i just wanted something like the bmw or audi lights i guess more looks then lighting
AWD Torque Monster
Originally posted by corey415
BMW and AUDI lights have more "bling" because of the projector HID setup, different from the reflector HID setup of the CL. Using high K bulbs may appear to have a higher "bling" factor, but less useable output.
BoricuaTL
04-08-2016 01:08 PM
