hid lights?
Old Apr 2, 2004 | 12:50 PM
plee84chc's Avatar
7th Gear
hid lights?
hi i saw on a website that there are d2r 6000 k and d2r 8000k i know that the 6000 k will fit on my cl but will the 8000k ones fit on there? and i want a look that will look purple or more blue so which bulb will be better? and what i sthe current k's on the stock bulbs on our cars?
Old Apr 2, 2004 | 12:56 PM
CLpower's Avatar
teh Senior Instigator
the 8000K and 6000K just represent the coloring from what I understand as long as it's a d2r you should be alright.
Old Apr 2, 2004 | 01:02 PM
juniorbean's Avatar
Keep in mind that the higher you go on temp, the lower the light output is. I believe the stocks are around 4200k, so personally I wouldn't go over 6000k as the 8000k are more for looks and less for actually lighting the way.....
Old Apr 2, 2004 | 02:05 PM
VXCL's Avatar
AWD Torque Monster
exactly! ur oem is 4100k but after burn in they are about 4300.
the only true 6000k bulb is the philips ultinons. anything else is coated and usually a cheap brand. at least make sure they are philips or osram bulbs if they are coated. personally i would just put philips d2s bulbs in. they will be brighter becuase there is no black coating on them. are you going for looks or light output?
Old Apr 2, 2004 | 02:31 PM
plee84chc's Avatar
7th Gear
there on plasmagarage.com but they said its the same thing as philps and they have the sam eligth output as them but i just wanted something like the bmw or audi lights i guess more looks then lighting
Old Apr 2, 2004 | 06:53 PM
corey415's Avatar
BMW and AUDI lights have more "bling" because of the projector HID setup, different from the reflector HID setup of the CL. Using high K bulbs may appear to have a higher "bling" factor, but less useable output.
Old Apr 2, 2004 | 07:53 PM
VXCL's Avatar
AWD Torque Monster
BRILLIANT! thats why my 1st gen has bmw projectors
Old Apr 2, 2004 | 08:16 PM
Chopsie's Avatar
Beware of leakage
Phillips or Osram D2s
BoricuaTL
Apr 8, 2016 01:08 PM
pozebly
Sep 23, 2015 07:30 AM
JnC
Sep 11, 2015 06:06 AM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
voigt
Sep 2, 2015 10:44 PM
