HID HIgh beam Question...
Hi.. AZ Peple!!
I'm really curious that how to change Xenon HID high beam from
just a regular high light bulb.
If i change just a high beam bulb, is that be HID high beam?
or have to change other things in it??
'08 MX5 GT 6spd.
Originally Posted by FTT*9266
Hi.. AZ Peple!!
"...is that be" English?
Im not sure if i understand you correctly or not but the high beam is not a HID light and you cant just plug a HID bulb in and have it be HID. You have to have a ballast for the high which our cars dont come stock with. hope that helps.
you might think about just replacing the high beam bulbs with Sylvania Silverstone bulbs...they approximate HID look and only cost about 30.00 for a set of 2
Adventurist.
There is no such thing as an HID high-beam bulb. Reason? Safety...
The amount of time to ignite the Hg/Xe gas inside the bulb is not short enough to produce a on-off effect of traditional lamps... Plus, in doing so, it would destroy a ballast. The only similuted HID high-beam bulb is the single use of an HID that uses actuated motors to reflect the beam in different directions... common on Audi, BMW, MB, etc. This is called bi-xenon technology.
Adventurist.
Originally Posted by getright
is it possilble to use/install one of these actuators in our cars or do you need a completely new casing and ballast?
'08 MX5 GT 6spd.
ny'r residing in maine
i have those in my highbeams, and let me be the first to say the look nothing or project nothing like HID's
![Bullshit](https://acurazine.com/forums/images/smilies/bs.gif)
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
