Hid Fog
Old Oct 15, 2003 | 05:35 AM
seth30887's Avatar
Hid Fog
Has anyone done a TRUE (not fake blue bulbs) High Intensity Discharge lighting conversion on the road lamps? I was thinking about dropping in 2 8500K Xenon systems in the fog lamps. I can't stand the yellow color of the fogs contrasting with the blue/white/purple glow of the HID head lamps. I'm pretty sure it is possible because HID's run at a lower wattage than standard halogen bulbs. Therefore creating less heat, so the plastic assembly of the fog lamps wouldn't be a problem. I assume?
Old Oct 15, 2003 | 05:46 AM
BEETROOT's Avatar
Yeehaw
thinking it would be a ton of $$ to do that for not all that much result
Old Oct 15, 2003 | 05:51 AM
seth30887's Avatar
I can pick up the kit for about $300 dollars... and HIDS are supposed to outlast the life of your car since they don't use a filament like standard bulbs. But yes, still a bit pricey.
Old Oct 15, 2003 | 05:56 AM
BEETROOT's Avatar
Yeehaw
only $300? thats not too bad. what do you plan on using can you post a pic or a link?
Old Oct 15, 2003 | 06:01 AM
seth30887's Avatar
Sure thing bro.. http://cgi.ebay.com/ebaymotors/ws/eB...tem=2436122298
Old Oct 15, 2003 | 06:05 AM
BEETROOT's Avatar
Yeehaw
check out the hella micros too...this would take replacing the whole road lamp not just the bulb, but I heard these look pretty nice.
at tire rack
Old Oct 15, 2003 | 06:10 AM
seth30887's Avatar
at tire rack
Hmmmmmmmm.. i like those too.. i wonder if i could somehow mount those inside the road lamps..
Old Oct 15, 2003 | 08:28 AM
NOLACLS's Avatar
I think someone did this already and it melted the housing....but im not sure. I think his name on here was infamuz or something like that...but if you do it let us know the results and you need to post pics!
Old Oct 15, 2003 | 08:41 AM
NOLACLS's Avatar
http://www.acura-cl.com/forums/showt...threadid=70394 look here...this is where he got them done...but I cant rember the outcome...I think they melted but im not 100%
BEETROOT's Avatar
Yeehaw
this is not really the same thing as putting in HID, but I just swapped my 01 road lamps for the black plastic housing in the 03, and I am going to mount some PIAA driving lamps in there. I saw it done with the hella micros and it looked really good.
Old Oct 15, 2003 | 08:49 AM
fuzzy02CLS's Avatar
Not HID but I did the same thing as Beetroot is doing...
http://community.webshots.com/photo/...92524586geBxrC
http://community.webshots.com/photo/...89451735xbFvbC
Old Oct 15, 2003 | 08:57 AM
BEETROOT's Avatar
Yeehaw
hey fuzzy that looks really good...exactly what I am doing. are those 001 solitaires?
I'm putting mine in this weekend...it seems pretty straight forward...did you have any problems? Have any advice?
Old Oct 15, 2003 | 09:03 AM
GoldieAlek's Avatar
what kind of bulbs I can put in there so it would look close to headlights (not yellow)
I m sure there is something with lower wattage what (what brand and what size)?
Old Oct 15, 2003 | 09:18 AM
BEETROOT's Avatar
Yeehaw
polarG m6, piaa 19224
any 168 wedge bulb. do a search you will find tons of info.
Old Oct 15, 2003 | 10:20 AM
seth30887's Avatar
Hey, check out this site, it has excellent information modifying the color(s) that are projected through the use of HIDs and projector elipsids. http://www.geocities.com/jvxdriver/h...ector_beam.htm
Old Oct 15, 2003 | 10:24 AM
fuzzy02CLS's Avatar
Beetroot
Yeah the 001's
Only problem I had was the passanger side light harness was too short. I had to splice in an extra few feet of 18gauge wire on that side. That was becuase I mounted the relay by the intake on the drivers side fender.
Old Oct 15, 2003 | 10:54 AM
withoutcomp1's Avatar
It will melt the lens, i know someone who did it, otherwise i would have done it a long time ago.
Old Oct 15, 2003 | 11:03 AM
seth30887's Avatar
Real HID(s) with Ballasts, or just the Higher watt blue bulbs? Because the Real HID(s) run at a lower wattage = less heat.
Old Oct 15, 2003 | 01:10 PM
Hobes's Avatar
He's right...HID's in the roadlamps will melt the fogs
I just got the Hella Micro DE HID fogs installed this weekend..they look amazing
take a look on the second page
Old Oct 15, 2003 | 01:52 PM
NOLACLS's Avatar
You talking about Infamuz...I know he did it and I think they melted the housing...and I think he is in NJ.
Old Oct 15, 2003 | 05:46 PM
serf21's Avatar
hobes, youre PM mail box is full!
Old Oct 15, 2003 | 06:00 PM
J.T.'s 3.2CL's Avatar
Has been sold for a while
That sucks it will melt the housing. Has anyone elese done this with no problems?
Old Oct 16, 2003 | 08:35 PM
God's Avatar
God
GOD Of ACURA-CL.COM
$ 700 for the Hella DE Xenon is pretty damn expensive for some fog lights is there anywhere else we can get them cheaper ?
Old Oct 17, 2003 | 05:23 AM
seth30887's Avatar
I've e-mailed and talked to this guy who has done many foglight conversions. He says, using heat resistant washers, that you can prevent any melting problems. I'm assuming, people are getting the DS2 HID bulbs to close to the outer casing because of the differences in sizes of the H3 standard bulbs, and the DS2 xenon. Take a look at this link, I am going to try it, I'll post pics when I get it done.
http://www.geocities.com/jvxdriver/d...conversion.htm
Old Oct 17, 2003 | 06:13 AM
webhead's Avatar
Racer X
I installed the Hella micro DE xenon foglights but I put them in the grill medial to the road lamps. I still have the road lamps in place but just changed the bulbs to a whiter color (PIAA). They are only for show anyways. . . I got the Hellas for about 450 on a VW jetta site.
Old Oct 17, 2003 | 06:56 AM
OscarCL3.2's Avatar
Go Gators
I put the Micro DE's in, and changed the bulbs to PIAA Xtreme White H3's...matches perfectly at night, but for some reason during the day they tend to look a little yellow, especially when they are dirty...
I would have purchased the Xenon DE's but I thought they were DRIVING lights, and not fogs? Am I wrong on this?
Old Oct 17, 2003 | 08:14 AM
GoldieAlek's Avatar
piaa 19224 wont melt anything right?
do you know what color will match close to stock headlights?
thanks
Old Oct 17, 2003 | 08:22 AM
BEETROOT's Avatar
Yeehaw
thanks
no, they won't melt anything. I had them for a few months with nothing bad happening. I don't remember what the exact color was, hyper white maybe? extreme white? something like that I think. The actual bulb was blue and the light looked pretty close to the HID color.
Old Oct 17, 2003 | 08:37 AM
usc's Avatar
usc
Uh... HID's bulbs run at the equivalent of 35W, but add the ballasts and you're looking closer to a total of 43W +/- a couple.
As for heat, HID bulbs are actually VERY hot at the capsule/arc. It's advantage is the lack of a metal filament to radiate the heat. If there's insufficient distance between the capsule and the surrounding plastic housing, the housing will distort/melt.
Old Oct 17, 2003 | 08:55 AM
rice cookr's Avatar
USC, Good post- you beat me to the punch. What these guys seem to be missing is the fact that wattage is not the biggest factor here, it's the dissapation of heat. HID's get MUCH hotter due to the nature of design, it's creating a friggin' PLAZMA beam!
Old Oct 17, 2003 | 09:20 AM
peiqinglong's Avatar
The CL's fake foglight housing can not handle the HIDs. THe TL's on the other hand can because they're made of glass.
Old Oct 17, 2003 | 09:30 AM
usc's Avatar
usc
I maybe mistakened but don't the TL's come with 9006 halogens for fogs? (which would naturally mean they're better built to withstand the heat.)
Old Oct 17, 2003 | 09:33 AM
seth30887's Avatar
so are you saying that these aftermarket 60-80 watt "hyper" bulbs are running cooler than HID's? I've seen more people burn out light sockets with these HIGH WATT advance auto special bulbs, than any true HID system. And a PLAZA beam? Where did that come from? When a voltage is applied across the HID gas capsule, it initiates an arc of ionised Xenon gas, which heats the enclosed metallic salts to vaporisation point. Once vaporisation of the salts has occurred, then the HID capsule produces its full light output. I'm not arguing the fact that HID bulbs get hot, because they do. But if installed properly, I don't think is should be an issue. The most important thing to remember is that the gas-filled capsule of HID bulb MUST fit inside the foglight housing at the same focal point as the original H3 halogen bulb. Otherwise, the bulb will be in a position to which it could cause damage to the actual plastic casing. This can be achieved with the use of heat resistant washers (as suggested) for spacing purposes. If your still confused about wattage creating more heat, GE (general electric) has been nice enough to post a site about lighting basics. http://www.gelighting.com/na/faq/basic_heat.html
Old Oct 17, 2003 | 09:47 AM
usc's Avatar
usc
yes, the 60-80W bulbs run cooler at the filament than at the arc of and HID. The reason the halogen bulbs melt the harness is because, as i'm sure you know, the filament is a resistor and the heat is translated back through the wiring. whereas in the capsule of the HID, it's just gas and ignited salt crystals, not a resistor that ends up harboring a lot of heat.
for the most part, any headlamp housing designed for halogens lamps (9006/9005/h4/h1/h3) should be able to handle the heat produced by the D2 bulbs of HID. but the CLS didn't come with 9006-fogs so therefore, Honda didn't have to use the higher temp-resistant plastic to form these. Stick a D2 in there and you got yourself a problem of melting the housing. (note "housing", not wiring/harness like high-wattage halogen replacements)
Old Oct 17, 2003 | 11:50 AM
seth30887's Avatar
[QUOTE]Originally posted by usc
[B]yes, the 60-80W bulbs run cooler at the filament than at the arc of and HID.....
Gotcha... I think I'll just leave them alone, I'm not gonna risk burning up my plastic housings and having a potential mess on my hands. Thanks for the advice.
Old Oct 17, 2003 | 04:21 PM
UNeeKLiNG's Avatar
check out st2000 pics..he had some hella micro with his custom grills on it...sorry i can't find the link righ tnow..but look him up...he had a badass set up if that helps any of yall
Jul 16, 2017 07:33 AM
Avenger411
Oct 11, 2015 03:53 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
rhdune16
Sep 28, 2015 11:31 AM
h22lude
Sep 27, 2015 06:22 PM
