Help with "X" CAI
Old Nov 30, 2001 | 09:51 PM
fender4's Avatar
Help with "X" CAI
Well I Broke down and bought a Xephyer from Park Ave. My questions are;
1)The unit has only one 90 degree bend, AEM has a slight 20 degree bend near the bottom. Do I have the right unit?
2) Are there suppose to be any lower mounting brackets? Seems like this thing is just connected to the throttle bodyand floating. PA said they were sending me the complete kit.
3) The end of the Air filter has a corner bent in about 2 inches, is this by design or has it been damaged? Shipping container has not been smashed.
4) What is the rubber ring for at throttle side? It looks like the tube should fit without it.
I got my "turning, clicking thing" and I 'm ready to install if this is the right unit.
Thanks for any help
Old Nov 30, 2001 | 10:03 PM
EricL's Avatar
I sent you a private message. What you want should be there.
Old Nov 30, 2001 | 10:39 PM
Amir's Avatar
BigPimpShyne
damn i thought that dude from xephyr caught out on yall niggas, what are you doin buyin his $hit...Shyne
Old Nov 30, 2001 | 11:17 PM
EricL's Avatar
Fender -- try having a look again...
Old Nov 30, 2001 | 11:43 PM
scl23's Avatar
Goldmember
Slim Shady
That tube sounds shady. You actually do need the rubber thing to reinforce it at the engine end. And there should be a stablizer part near the middle that bolts with a rubber buffer to the frame. My InJen has a bend that makes the filter face forward.
Old Nov 30, 2001 | 11:46 PM
SilverKnight's Avatar
Retired. Not available.
Re: Help with "X" CAI
Thanks for any help
[/B]
Regarding the rubber ring, from what I saw on pictures, the pipe is 2.75" so you need the ring, otherwise, it's too small for the stock rubber hose. I used to have my own CAI with the same setup, take a look, maybe it helps.
Old Dec 1, 2001 | 12:11 AM
WI CLTypeS's Avatar
Blue Devil
Re: Slim Shady
If I remember correctly that bend in your Injen isn't nessecarilly a good thing. I think it was something around every 90 degree bend in a pipe equals out to 10 ft of length??? Don't remember thermodynamics and fluid dynamics too well right now.
So the less bends and the less degree of bends is a good thing. Hence the reason the 'X' CAI and AEM CAI face downwards.
Don't flame if I'm wrong, just nicely tell me to shove it!!
Old Dec 1, 2001 | 12:27 AM
fender4's Avatar
$199.00 including bypass, also PA already paid for it so why not.
Old Dec 1, 2001 | 07:45 AM
wayneg's Avatar
Fender4- That is the correct unit for your car. All the necessary hardware was included- if you are missing anything- let us know. If you need further help- shoot an email or message to Jens and he will be glad to talk you through it.
Old Dec 1, 2001 | 08:03 AM
CO-CL-S's Avatar
Actually the CAI he made was a good one, best value on the market. Unfortunately the business did not work out right and he was not able to handle the adversity. What is "niggas"?
Old Dec 1, 2001 | 09:08 AM
soopa's Avatar
The Creator
well... he didn't buy it from X... he bought it from PAA... so all he's doing is helping get PAA back the money X outted them on.
wayne, you guys got any left?
Old Dec 1, 2001 | 09:14 AM
soopa's Avatar
The Creator
and as for all these comments on the "design"
these oddities werent "engineered" to be a feature.
its just that all X did was buy a standard mandrel bent tube, which you can order from anywhere in a standard 2.75 or 3" diameter... and it cost less with less bends. Also... the fact that its a 90 degree bend may or may not be intentional... it would be much cheaper to get a pipe with a 90 degree bend ad have it cut to a certain length on each axis rather then get a custom bend.
The X cai is not MADE for our car's at all... its just a pipe. With a cone filter... that you can jerry rig in there.
Either way... in its defense... it works... and it gets the job done damn near as well as the others.
And I do believe its a 3" diameter tube. Could be wrong though... but I was pretty sure... and I know that the sidewalls are same thickness as the others.
It is a quality tube. There just wasnt much R&D into the fitment of it.
Old Dec 1, 2001 | 09:20 AM
fender4's Avatar
att Wayneg You have mail
lanechanger
Oct 13, 2015 10:56 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
h22lude
Sep 27, 2015 06:22 PM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
DDTsx06
Sep 8, 2015 06:56 PM
