HELP...taillight problem
Old Sep 10, 2002 | 08:02 PM
limuas22's Avatar
I'd rather be golfing
I have the following problem:
When I push my brakes, the tail lamp lights like it should.
Also when I put my gear in reverse, the tail lamp lights like it should.
But when I turn my lights on nothing lights up on the taillamp.
This is only happening on my left side tail lamp. I've checked all the connections 3 or 4 times, and took everything out and put it together and still get the same problem. Also all the bulbs are in working condition since they all light up.
Anyone have any ideas? Is it a fuse problem?
Old Sep 10, 2002 | 08:04 PM
monkeymato's Avatar
Buckle Up
I think that the bulbs have 2 filiments in them. One for regular driving and the other one lights up when you brake. One of them might be out. I dont know...I'm just guessing here. any experts?
Old Sep 11, 2002 | 10:40 AM
limuas22's Avatar
Thanks monkeymato...can anyone confirm this?
Old Sep 11, 2002 | 10:46 AM
SinnedTL's Avatar
Ain't No Other...
yes the brake lights for the tail-lamps are dual filament, hence it brightens up when you brake... ALWAYS check the bulb first if anything goes wrong with lights, because usually connections dont really go bad...you made the first mistake by not checking the bulbs...
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
