help! squeaky brakes!
Old Nov 29, 2005 | 10:59 PM
BrutusHayes's Avatar
ok i got my rotoras last year and installed them with the cheap satisfied pro OEM pads that i got from tire rack.. now the rears are squeaking like crazy..
i've taken the pads off and they have a ton of life left.. there is barely any wear on it.. is there anything i can do about this? is there possibly something i did wrong in installation that might have caused this? they worked fine for about a year but now they're horrible..
can i just replace the rear pads with a different brand or material (possibly ceramic) while keeping the old pads on the front?
Old Nov 29, 2005 | 11:37 PM
NiteQwill's Avatar
Adventurist.
Apply Brake Squeal
Metallic pads will not squeal. Adding ceramic pads will only make you have a permanent squeal.
Old Nov 30, 2005 | 08:33 AM
RaviNJCLs's Avatar
I have EBC Greenstuff pads and they hardly squeal. Maybe you can give those a try.
Old Nov 30, 2005 | 08:45 AM
anothercls's Avatar
Brake squeal from the autoparts store should cost a couple dollars and be able to take care of the problem.
Old Dec 1, 2005 | 01:21 PM
thanks for the brake squeal suggestion.. i got some and it has seemed to take care of the problem so far.. no more squeal.. regardless, i don't think i will ever get the satisfied pro pads again..
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
