help someone.. need radio code
drop em like its hot
Hey guys... i just installed my transmission cooler today and the mechanic had taken the battery off.. hence my radio reset itself and i need the code to play it. can anyone get the radio code for me? if you can help me out i'll PM the info you need to get me my code.. thanks
-rez
-rez
2004 Euro Cup Champions
yup check in the books. Its called "safe mode"
punch in the code and you are all good. BTW , they are all unique and if you lose it. Then you will have to have the dealer run a search on your particular radio through their database. it sucks.
I have a 01 CLS and my code was located on the outside of the glove box. If you sit in the drivers seat and open the glove box you should see a little white sticker on the side of the outside of the glove box with your five digit code. I called local dealer parts dept and they said to pull the radio and bring it in to get the model/serial numbers. My contact in the service dept said to look in the glove box. Great communication there....
thanks... hopefully my dealer put it there where yours is tampa, and it sounds like a dealer put it in there for you too kevin... will check and let you guys know.. thanks
so annoying cruisin without tunes...
-rez
-rez
Audi S4 driver
something I just found out today. Are you registed to Acura Owners Link site? I just noticed today that under your vehicle information it tells you your radio code.
Audi S4 driver
No I never put mine in. I'm positive of it. When you sign up for owners link you just put in your VIN and it pulls up all the information of the car. It also has all the specs off my window sticker and I know for sure I didnt put that crap in?!? Seriously go look .. trust me its there.
I couldnt have put it in because my dealer wrote the wrong code in my book. so I didnt realize I had the wrong code til I installed the AEM at 8k miles. but I signed up for owners link like the day I bought the car and it has the right code listed on the site.
hey i found out from acura client services how to find out our serial # for our stock radios without taking out the console to see the serial...
turn the car on, not the ignition (2nd position where electronics are on but motor is off) and turn on the radio to check that the CODE is on the radio. turn off the radio and hold down 1 and 6 simultaneously. turn on the radio while still holding down 1 and 6 and the radio will display 2 screens - U XXXX and L XXXX (x's stand for numbers) the 8 numbers shown will be your radio serial#... worked on my 2001 cl and i called acura and got my radio code
mine is also on the outside of the glove box in my '03 CLS. from the drive's seat if you open the glove box you can see a tag with a code (i think its 5 digits) on the side panel facing the driver.
Everytime I get my oil changed at the dealer, I notice that my radio code is on the receipt. You might want to look at that ... then again, if your dealer wrote the wrong code in your book, they might have the wrong code in their service records.
dirleton
08-06-2024 08:19 PM
Jamus22
06-11-2023 10:08 AM
