help with reverse mirror
Old Sep 12, 2008 | 04:13 PM
drtyjerzCLS's Avatar
i have a issue with my passenger mirror when u put it in reverse it used to go down so i can see the curb but ever since i got it back from the bodyshop this feature does not work its all connected properly is there a way to reset or reprogram this feature ??
Old Sep 12, 2008 | 04:17 PM
ChucksCL-S's Avatar
To reset check owners manual, it will work.
Old Sep 12, 2008 | 04:26 PM
ChucksCL-S's Avatar
Here you go, I looked it up. Turn ignition on. Slide mirror toggle to "R" (right side mirror". This toggle switch is on the drivers door armrest. Adjust mirror normally. Then move switch to the center position. Mirror will now move downward in reverse.
Old Sep 12, 2008 | 05:40 PM
it didnt work
Old Sep 12, 2008 | 08:06 PM
Allout's Avatar
Blown is Best
Just to double check the obvious - Is the left/right mirror switch in the middle?
Old Sep 12, 2008 | 09:54 PM
yes.... i did as it says above i got in turn the key to ignition placed the swith to the right adjusted the mirror then put it back in the middle position i turned the car on and tried to reverse mirror did not move in the middle or any other position
Old Sep 12, 2008 | 10:34 PM
nspec_ya4's Avatar
Regional Coordinator (Texas)
r ur reverse lights coming on?
Old Sep 12, 2008 | 11:08 PM
VIPCLS's Avatar
P.
Man sorry to hear that. Most likely u have a broken unit. Go to the dealer or do a seach on AZ.
Old Sep 13, 2008 | 03:33 AM
swoleCL's Avatar
¿baCon?
only good for not curbing your wheels... if your an experienced driver its not that big of a deal.
Old Sep 13, 2008 | 03:52 PM
GreenMonster's Avatar
You could always disconnect the battery (negative terminal) to reset... just make sure you have your radio code since you'll need that after disconnecting power...
Might work, might not, but it's easy and cheap thing to try...
Old Nov 20, 2008 | 11:13 PM
monkeybutt's Avatar
Thanks ChuckCL-S. Until I read this thread I had forgotten that the CL-S did this.
ITSJESTER
17
Dec 6, 2018 02:29 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
soupi
14
Nov 15, 2015 11:15 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
STC
Sep 23, 2015 04:36 PM
