Help! replace rear brake pads
I replace my own brake pads most of the time. Has anyone replaced the rear pads can share with me the experience. Is there any special tool or procedure involved that I should be aware of? I recently helped a friend with his Passat's rear pad. It required a special tool and was a bitch to replace even with the special tool
Thanks in advance
![Mad](https://acurazine.com/forums/images/smilies/mad.gif)
whoXwanXsum
IF the rear has what i think it has...
instead of using a clamp like you do on the fronts...you'll ''turn'' the cylinder down with the special tool. iused a long screw driver when i did the rears on my tl. i'm due for brakes also...
The rear caliper's piston needs to be "rotated back in" instead of pushed back in as the front ones. You need a special tool that looks like a little square with edges. The rear caliper piston does not have a smooth surface but with an "X" etched in it. This tool has a socket that allows you to insert a 3/8" screwdriver/wrench in it and turn. If you don't have this tool, you'll need a thin long rod that you can fit in there in order to rotate it back in.
Oh, and leave the brake fluid reservoir cap off while doing this, otherwise, your fluid will overflow or the piston simply doesn't move.
Location: Somewhere between here and there, yet neither.
If you're replacing your rear pads....you might wanna take a look at your drum shoes as well. I'm about to replace my rotors again (75k).
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Received 7,143 Likes
Originally posted by mr tl
the pistons on my tl just pushed back in, without turning. i used a clamp
![Stupid](https://acurazine.com/forums/images/smilies/imwithstupid.gif)
Originally posted by SilverKnight
moomaster, you think the drum shoes could wear out because of parking?
mada51589
05-03-2022 08:54 PM
