HELP! removing spark plugs
Old Aug 7, 2003 | 12:06 PM
keith419's Avatar
7th Gear
Anyone have any tips on removing the back three spark plugs? The 2001 CL-s has the plugs hidden in the back. Any help would be great.
PS I have 110,000 miles on the original plugs. They were still ok, but the tips were a bit short.
Old Aug 7, 2003 | 12:15 PM
fuzzy02CLS's Avatar
110,000 miles! Wow that may be the most miles on any CLS
Old Aug 7, 2003 | 12:17 PM
Juker008's Avatar
TRELOS
I origionally thought that changing out the rears were hard, no not at all. All that u need to do is remove the Actuator, 5 mins. Be sure to use a spark plug socket, so that the sparkies don't fall in the engine bay. And if they are somewhat tough to get out use some WD40.
Oh and when u replace the new ones don't forget to install teh new ones with anti-sieze compound on the threads and silicone on in the socket boot for the sparkies.
Juker008
Old Aug 7, 2003 | 01:01 PM
danny25's Avatar
I didn't remove the actuator to get to the back plugs, but that probably makes it easier. It really isn't that difficult. You just have to be able to sqeeze your arm down there, and lay on the engine at times.
Old Aug 7, 2003 | 01:33 PM
mantis23's Avatar
Moderator Alumnus
It was a pain manipulating your arm at times, but it will eventually work... ain't that right, Danny?
Danny helped me do mine.
Old Aug 7, 2003 | 01:41 PM
keith419's Avatar
7th Gear
Thanks!
It was much easier when I removed the actuator bypass valve and an oil line.
On a seperate post, I will send a picture of the original, 110K, plug.
Thanks!
Old Aug 7, 2003 | 01:58 PM
danny25's Avatar
Re: Thanks!
was that complicated? I haven't looked to see what that involves.
Old Aug 7, 2003 | 06:12 PM
Juker008's Avatar
TRELOS
Re: Thanks!
Huh :confussesd:
oil line???
Juker008
LeVeL
Oct 18, 2015 04:19 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
polish_pat
Sep 25, 2015 12:24 PM
STL TL-S
Sep 23, 2015 08:52 PM
Cexarin
Sep 23, 2015 07:43 PM
