Help on reducing wheel hop
Old Mar 17, 2006 | 04:28 AM
rtatsutani's Avatar
Never had a clean run
My car used to burn out smoothly on wet or dry ground, but after installing the cooling mods and unichip, I get mad wheel hop. I don't know if my tires are getting stickier or what but I need help on reducing it.
I have the adjustable height Tein coil overs but not the model with adjustable dampening. I have adjusted it to about a one finger gap and have had all four tires aligned and adjusted with rear cambers. Would lowering or raising my car help with wheel hop? Should I get a pair of super street damper shocks for the front to help fix this issue, or are there other more cost effective ways to do this?
Old Mar 17, 2006 | 04:50 AM
cvschoolboy209's Avatar
well with my 2.2cl i use to have that problem with wheel hopping but i figured it out that its all about balancing the gas and clutch i dont know if its the answer but after i learned i eliminated wheel hopping from my burn outs and launches
Old Mar 17, 2006 | 07:21 AM
CleanCL's Avatar
fill your motor/tranny mounts with polyurethane.
that should just about solve most of your issues unless your hitting real hard, in which case check this out:
http://www.v6performance.net/forums/...ad.php?t=61909
i think upgrading your rear swaybar will help a little with some of the weight dist.
Old Mar 21, 2006 | 12:53 AM
Allout's Avatar
Blown is Best
Sway bar will only help with left/right body roll. Try stiffening up the dampening on your struts and see what that does.
Old Mar 21, 2006 | 01:13 AM
CleanCL's Avatar
i won't deny that sway bars main purpose is to help on turns.
maybe it's in my head, but when i install aftermarket sway bars w/ poly bushings, i notice the car 'bounces' a lot less on bumps/dips while going straight. more noticeable with an upgraded rear bar in a FWD car.
Old Mar 21, 2006 | 01:49 AM
NiteQwill's Avatar
Adventurist.
Have a machineshop build you some custom reinforced dogbones.
Old Mar 21, 2006 | 04:14 AM
rtatsutani's Avatar
Getting a price from my garage right now about putting in polyurethane and the engine dampener as well. Both sound really good. I'll let you guys know how it goes when/if I am able to get them in.
Old Mar 21, 2006 | 04:18 AM
rtatsutani's Avatar
Wow, great idea. Did some reading up on this and it looks very promising.
Gonna stick with the more common methods (polyurethane and dampener) first, then if that doesn't do the trick, I'm definitely looking into the custom dogbones.
Thanks!
Old Mar 24, 2006 | 07:02 AM
poisx7's Avatar
will it fit in the 2nd gen cl with stock sway bar
Thanks!
looking at this damper here:
http://www.v6performance.net/forums...ead.php?t=61909
will it fit in the 2nd gen cl type s with the stock sway bars in the engine bay
Old Mar 25, 2006 | 02:10 AM
NiteQwill's Avatar
Adventurist.
Thanks!
No problem. Let me warn you though, with stiffer dogbones, the car will vibrate more. I mean, you will "feel" the car more. Can get annoying, but it's bearable.
This will almost completely eliminate wheel hop.
Old Mar 25, 2006 | 05:43 AM
01suncls's Avatar
convert it to rear wheel drive!!! haha
Old Mar 25, 2006 | 02:52 PM
mclarenf3387's Avatar
RWD cars can get wheel hop too
Old Mar 26, 2006 | 01:33 PM
01suncls's Avatar
yeah in a truck... i've never experienced wheel hop has bad as my cl! still love it though!
Old Mar 26, 2006 | 01:50 PM
rtatsutani's Avatar
Has anyone heard of sliding in urethane inserts into the motor mount spaces? My shop said I can look into that as well, probably easier for them to install since they won't have to completely remove, inject and let dry then reinstall. I imagine the polyurethane would be better since there would be no play like an insert would have?
Old Mar 26, 2006 | 05:27 PM
CleanCL's Avatar
i will be filling them with poly. how are you going to get an insert in there wtihout removing the mounts?
Old Mar 26, 2006 | 05:42 PM
732xghost's Avatar
maybe not doing burnouts anymore....
my 2.2 is the worst for doing burnouts as soon as i dump the clutch my shit is like a basketball.
Old Mar 26, 2006 | 07:30 PM
johntypes's Avatar
dont do it the ride is so hard ,I changed mine the following year, if you do it there will be no wheel hop
Old Mar 26, 2006 | 07:44 PM
CleanCL's Avatar
fill the mounts with polyuretane?
Old Mar 28, 2006 | 03:37 PM
Louie11's Avatar
No he's talking about retrofiting polyurethane bushings in the control arms. I'm actually having this done next month. My suspension is already stiff so I won't mind.
Old Mar 28, 2006 | 03:49 PM
CleanCL's Avatar
ah, ok. aren't the control arms on our car the biggest source of traction loss?
Old Mar 28, 2006 | 04:59 PM
johntypes's Avatar
CleanCL
Rtatsutani
You guys will be sorry, i told you I did it you have no springs left the hardist ride compared to a GO cart.
Old Mar 28, 2006 | 05:05 PM
CLsuperhero's Avatar
I say an engine dampener should be all you need unless you have an insane set up under the hood. I think the dampener should keep the motor from raising or moving around dramatically reducing the wheel hop.
Old Mar 28, 2006 | 08:11 PM
CleanCL's Avatar
CleanCL
Rtatsutani
i'm not replacing control arm.
i'm only filling the front and rear hydraulic mounts with poly, and the left side mount with poly. and possibly adapting a damper.
no thanks to control arms though. thanks for the info though.
Feb 25, 2020 09:57 AM
ExcelerateRep
Dec 11, 2015 12:58 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
tealt
Sep 1, 2015 09:03 AM
