HELP! Problem with Legend brake install
After reading numerous reviews on the 95 Legend calipers I decided this would be an easy DIY. So far, not as easy nor as much fun as I was hoping for.
Got the 2 piston Legend calipers, Rotora slotted rotors, EBC Greenstuff pads and Goodridge stainless steel lines.
It was an easy install, but the pedal was mushy so I bled them twice (around 15 pumps each) from 1.) rear right 2.) rear left 3.) front right 4. ) front left. The pedal was mushy going all the way to the floor and the brakes only kicked in after 3 to 4 pumps.
Thinking that I may not have bleed all the air out, I took the car into the shop. They bled the system twice. Still no improvement on pedal or stopping.
Thinking that the remanufactured calipers were faulty, I took them off and put the stock calipers back on. Bled the system again. Still no improvement on pedal or stopping power.
AAARRRGGHH!!! What the heck is going on? Any advice or suggestions would greatly be appreciated.
The only thing that I can think is that something is wrong with the brake lines. I did check for kinks (none) and for leaks (none). Plus I'm not losing any fluid from the master cylinder.
Hmm, so your reserve is filled with brake fluid. Dumb question, make sure its dot 4.
Umm, if you're not leaking and you didnt puncture your brake lines.
It has to be air in the system, are you sure that the people are constantly keeping the master cylinder full of brake fluid when they are bleeding it.
Also, what method did you use to bleed the brakes. Because this is the only area where there can be an issue. If the master cylinder isnt busted and you have no leaks, by way of elimination it has to be the bleeding process or bad calipers.
But you said you put your old calipers on, so I am just trying to deduce what it might be. Good luck, maybe u can give us more details
Sounds like there is a ton of air in there. When I had my set up installed, a local mechanic did it, and he said it wasn't too tough, but he had a pressure bleeder. When I had them removed, it took forever to bleed it with one of the cheep bleeder.
Definately make sure you used the correct fluid. I heard some great stories about using the wrong one.
And I agree with pits that it seems like the problem is not the calipers.
Good luck, keep us posted. And I can say from experience that you would appreciate the extra stopping power of this set-up vs stock.
Former Sponsor
Originally Posted by fuzzy02CLS
At anytime did you run the master cylinder dry? Cause if you did & you got air into the brake booster, your screwed. This can only be bled by a special machine(dealer) to get the air out.
Originally Posted by Excelerate
I'd be willing to bet you the let the master cylinder go dry while you were bleeding. You have to keep that master cylinder full or as you bleed out the lines (without keeping the cylinder full) you will be sending more air in the lines and the MC. Now you have air in your MC more than likely.
I went to the dealer today who completed the flush and the braking power is definitely restored.
Also, be prepared to eat through those brake pads. I did with the NSX calipers.
Just FYI, the bleed process for the brakes on our cars is the opposite of what you listed.
On the CLs, you start closest to the master cylinder (front drivers side) and work to the farthest caliper (rear passenger side).
Originally Posted by RaviNJCLs
How does it feel?
Yeah, I read your post about eating through EBC pads, oh well still a good upgrade.
Originally Posted by superfob
Where did you find the calipers? I was thinking of getting some from Kragen Auto Parts.
ULOOZ
Are the rotors and the pads NEW? you can get a spongy pedal if you do not machine the rotors and just replace the pads... . If the brake pedal was depressed "fully" to bleed the brakes it is possible you may have ruined the seal internally within the master. Also.. make sure the calipers you bought are not bent.
Originally Posted by 4ank
I'd like to know this as well. Also, is there a DIY out there? And what does something like this run total dollar?
I paid about $850 for all the parts for mine. I got calipers, rotors, brake lines and pads. Of course a BBK would be better, but this is about half the cost.
I had a local machenic do the install and he had it done in about 2 hours. It's really not too hard to do. You take off the stock calipers and install the NSX ones. Same brackets. The hardest thing is bleeding the brakes.
They are calipers for a 1995 Acura Legend GS
191744 and 191745
I got mine from Autozone ($50 for calipers, $50 core deposit).
My bill came out to:
$100 for calipers
$115 for pads
$300 for rotors
$120 for Goodridge brake lines
$130 (bc I was an idiot and got air in the master cylinder and had the dealer powerflush the system)
Also...very important, on the install be sure to swap the right and left calipers.
the "poor man's BBK"
i got them remanufactured from napa for $55 each plus $66 core charge each. Just ask for 1995 Legend LS coupe front calipers and swap left for right (the bleeder bolt has to be on the top of the caliper when installed, you'll see what I mean). you only need the Legend caliper itself. use all of the existing CL's mounting hardware.
while you're at it, install stainless steel brake lines (~$110 from Excelerate).
i don't think they're different, but to be safe you'll want brake pads for a 1995 Legend LS coupe front, not the CL pads.
when you're done, just put your single piston CL calipers in the boxes and take them back for the core charge. they won't even open the box.
is the stopping power so improved that everyone needs to upgrade? debatable, but i'm very happy with the improved stopping power for $110+time for labor (i dyi'ed). the best way i can describe the improvement is to say that the pedal is much more "confident".
i've just now put on about 500 miles, so i'm ready for the bedding procedure.
here's some pics of mine when i first installed them:
https://acurazine.com/forums/ramblings-12/test-181612/
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
