Help. Hood will not open.
That's hot...
My hood won't open for some reason. I pulled on the lever and nothing happens. Is there anyway to get the hood open or fix this problem? Let me know thanks.
Masshole
Try pulling the lever and leaving it out. Then, go to the front of the car and push down on the middle of the hood above the latch, it may release. If it does, you should probably lubricate your trunk release and your lever cable inside the car. If your cable broke, hit the dealer.
Try to get to the latch from underneath the car. You should see the spring loaded assembly from underneath, put a screw driver up to the side of the arm that holds the hood latch, and whack the screw driver with a hammer to compress the spring and release the latch. Used to do that all the time on my Lincoln due to heavy rusting.
Dealer or mechanic should be able to do this for you if you can't.
Good luck.
Good luck.
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
