HELP:Headlight lens scratches!!!!!
They were there when i bought the car, they just werent as obvious. They are right next to where the hood meets witht the heaslights. You can tell they are from a buffer. How would you guys go about removeing them or making them less visable??
Thanks for the help
Thanks for the help
You could use a few different grits starting with a rougher then finishing with a finer grit. Make sure you are WET sanding, without the water you could do a lot of damage.
I recommend starting with 1000 Grit being the roughest and finishing with at least 2000 Grit if not finer. Then you should use some micro finishing compound to buff then finish it with a quality compound. Be sure not to burn the plastic while buffing though.
Originally Posted by gaping46and2
Before going the wetsand route, maybe try using Meg's Platix, or Poorboy's SSR.
https://acurazine.com/forums/showthr...ight=wetsanded
this dude just did it and gave some pointers too
+10 for wetsanding...
another DIY from the TL section
https://acurazine.com/forums/showthr...ight=sandpaper
go to walmart... on the aisle w/touch up paint there is a $15 kit you can buy. small buffing pads coated with really fine grit compound. sray water on the headlight and attach the pad to a drill... its pretty simple, and it took every scratch / haze / crusted bug off my headlights. like brand new!
Originally Posted by cltypeSLOW
i have used the plastix before. it seems to yield good results temp, but they tend to come back.
Very true. I had SOME results using Plastix, but I used PB's SSR2.5 the other day, and it seemed to have done a much better job. I've still yet to see the car dry, to tell if it's actually done it's job, hopfully in a day or two we'll be all thawed out.
InFaMouSLink
Oct 30, 2015 09:43 AM
