help with exhaust question
Old Jul 19, 2004 | 11:54 PM
racersky's Avatar
I know I'm a newbie at all this car stuff but one must start learning somewhere right? ok i have a question about exhaust systems. What's the difference between axleback and a catback exhaust? please be specific if you can thx.
Old Jul 20, 2004 | 12:10 AM
BEETROOT's Avatar
Yeehaw
axleback means just the mufflers...
catback is all the pipe to run the length of the car, from the catalytic converter to the rear of the car.
Old Jul 20, 2004 | 12:33 AM
Dem1K's Avatar
Got a Job!
well...the axleback DOES include a LITTLE bit of piping...bout 2-3 feet long, to reach to the rear axle...hence the "AXLEback" and the "CATback"
Old Jul 20, 2004 | 12:51 AM
NSX-Tuner's Avatar
boosted is best
Axleback Exhaust
Catback Exhaust
Old Jul 20, 2004 | 01:15 AM
racersky's Avatar
so what would you recommend me getting? for my CLP?
Old Jul 20, 2004 | 01:30 AM
Dem1K's Avatar
Got a Job!
depends...the catback will give you about 3-5whp I believe, and will be a tad bit louder...
the axleback is mainly for the sound...so if you're on a budget and just want sound, get the axlebacks
Old Jul 20, 2004 | 02:09 AM
racersky's Avatar
can i buy the cat seperate if i go axle?
Old Jul 20, 2004 | 02:11 AM
Dem1K's Avatar
Got a Job!
the cat as in the catalytic converter or the piping to make the cat back? because you'll keep your catalytic converter either way. If you meant, could you buy the piping to TURN it IN to a cat-back down the line, then yes, you can. Comptech sells teh piping alone which is called the B-pipe.
Old Jul 20, 2004 | 09:38 AM
bigman's Avatar
'Big Daddy Diggler'
If you have a CL-P you will notice an increase in power from a cat back setup due to small exhaust piping. A nice 2.25 inch setup will work nice for you. I think the comptech 2.5 inch setup will make you loose valuable torque, plus you wont make much power to the tip top of the power band. Now if you have an S, you will not see that much improvment over stock if you go with a cat back. Axel back will be perfect for you and will give you a couple horses. If you plan on going all aout and doing headers, intake, and other bolt ons, than do a cat back with a high flow Y and a good 12-22 inch resonator, you will love the difference in sound.
Old Jul 20, 2004 | 09:44 AM
NSX-Tuner's Avatar
boosted is best
Yes, the b-pipe can be bought seperately.
Old Jul 20, 2004 | 09:53 AM
NSX-Tuner's Avatar
boosted is best
My 03 CLS 6MT with CT i/h/b-pipe/e dyno'd at 236 WHP/201 TQ. The b-pipe added about 3-4 WHP and improved drive-ability across the entire rev range. I didn't notice any lost torque down low, but did feel more TQ higher up.
After installing the S/C, car dyno'd at 305 WHP/262 TQ. The b-pipe probably added 5-8 WHP. When Red Rider finally gets his car dyno'd again at CompTech, we can get a better feel on exactly how much was gained on a 5AT running with the b-pipe. He last dyno'd at 269 WHP running the i/sc/h/e. BTW - we both dyno'd are cars at CompTech.
IIDXholic
Oct 8, 2015 07:53 AM
Billu99tl
Sep 13, 2015 11:30 AM
datadr
Sep 12, 2015 09:12 PM
Hau_nguyen91
Sep 6, 2015 12:53 PM
