help, engine problems...
Old Aug 15, 2003 | 03:08 PM
BrendanCL TypeS's Avatar
www.WeDontDrink.com
my friend just bought an 1998.5 audi a4 quatro 1.8t and he took it to a mechanic today (it was running great) and had it checked. one of the things they did was a compression test. when i picked it up to drive it home, it wouldnt go above 1,000 rpm, it was sputtering, making a ticking sound, shaking, and it was emitting black smoke from the exhaust. i took out the pulgs, the tips were black, replaced them and it is still doing it.
any idea what is causing this?
Old Aug 15, 2003 | 04:11 PM
CLpower's Avatar
teh Senior Instigator
I've heard people ruin their motors doing a CT. Never seen it in person, couldn't imagine how you could fuck it up that bad.
Old Aug 15, 2003 | 04:15 PM
www.WeDontDrink.com
so what should i do? any ideas?
Old Aug 15, 2003 | 05:48 PM
www.WeDontDrink.com
need help please post ideas, thank you
Old Aug 15, 2003 | 05:55 PM
Chemmech's Avatar
You didn't get gas on the way home did you??? If you did it was probably diesel. The plug wires could have been mixedup, firing order is wrong. Yeah that's probably what happened, it's most likely something very simple to fix. Good luck, and keep us updated.
Old Aug 15, 2003 | 05:57 PM
www.WeDontDrink.com
yes i did get gas but it was 93. good idea. i had to thank about that one as well!!
Old Aug 15, 2003 | 05:59 PM
Chemmech's Avatar
Check my post above I just edited it.
Old Aug 15, 2003 | 06:02 PM
www.WeDontDrink.com
i will check that!! thanks but i think i already did and the order is correct but i will check
Old Aug 15, 2003 | 06:03 PM
NSXNEXT's Avatar
You picked it up and the mechanic and it started to act weird. Well I ain't no mechanic, but.....
TAKE IT BACK TO THE MECHANIC. Don't touch the car. Call them and tell them what is happening. Anything you do to the car could void any claims you have with the mechanic.
Old Aug 15, 2003 | 06:07 PM
Chemmech's Avatar
Good luck! Yeah what NSXNEXT said is solid advice, don't tell them that you even touched the car.
SidhuSaaB
May 30, 2020 12:40 AM
BIGxRED
Oct 19, 2015 10:47 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
