Help Engine Light Problem
Ok I Ran My Friends Scanner Today And There Were 10 Codes
1.p0141 O2 Sensor Heater Curcuit Malfunction (bank 1 Sensor 2)
2.p0301 Cylinder 1 Misfire
3.p0302 Cylinder 2 Misfire
4.p0303 Cylinder 3 Misfire
5.p0304 Cylinder 4 Misfire
6.p0305 Cylinder 5 Misfire
7.p0306 Cylinder 6 Misfire
8.p0219 Engine Overspeed Condition
9.p0360 Ignition Coil J Primary/secondary Curcuit Malfunction
10.p1399pd Manufacturer Contrl Ignition System Or Misfire
Can You Guys Tell Me What I Need To Do To Fix All These Problems/
What Should I Buy?
Let Me Know Step By Step Thanks
What Should I Buy?
Moderator Alumnus
Replace both o2 sensors, ignition coils, plugs, and maybe new wires too (runs to the plugs).
Check the knock sensor...located underneath the intake manifold. It's a bitch to get to.
Did you try seeing how fast your car went too?
Were you racing the crap out of your car and over revving the engine?
Over revving can burn up the internals very quickly causing misfires.
Your car sounds pretty f'ed up .
If you're not too sure what you're doing, take it to the dealer. You may want to lube up, because the bill may feel like you were violated by a prison gang bang.
hey you guys u think i should just go trade in my car for a s2000, fuck i looked up some prices that shit is a rip ?
see what happens when ur young, dumb and full of cum
hey now i only have this, so im going to get my timing fix this comin up weekend and some other code that said multi cylinder misfire mulfu
and i also had a 94 Prelude Vtec before the CL
PS the car runs alot better with the new SparkPlugs
HeloDown
09-08-2015 06:51 PM
