Help. Engine Grinding
Started a bit ago.
When over 2K RPM, the engine towards the back valve cover vibrates horribly, amd makes a grinding noise. Even when in IDLE. I thought it was the tranny but doubt it since in idle.
ANY IDEAS? HELP....
ANY IDEAS? HELP....
Received 7,476 Likes
Can't even guess, but if it sounds that bad, I sure wouldn't drive it anywhere!!
No, it just started all of a sudden.. I have a appointment tomorrow to get it checked out, They said to drive it there, so I'll let you know of what happens.
Well here is the Update. Dealer Says ...... TRANNY # 4 Being installed. Should be done by Next Tuesday. Man I'm tired of this. Car is torn apart too since I had to run the wire for the XM to my headunit. Then it rained, and then had it towed so I got a Chevy Malibu for a week about.
i called and complained after my 2nd tranny replacement and they sent me a check for a month's payment.
do not settle for less, at this point, if you did not do this b 4, u should get 2 months payments!!!
Thanks for the Info, I didn't read the post with the Number in it. I'll give them a call tomorrow. Thanks for the info. Do you think it would be possible to Lemon Law the car? Then I could get a 6Speed Instead of having to deal with the Auto Trans... ?
Originally posted by BSK181
did you call that 800 number i posted recently 382 2238
Mike Bertram
09-10-2015 09:27 AM
