Help! DownPipe Question
I have a set of XSPower Headers and Downpipe. I recently got the flex pipe removed. I'm pretty sure I got the flange that bolts to the cat to line up pretty good to when the flex pipe was in the downpipe. How much play is there in the exhaust does it have to be perfect or could it be muscled in if needed? Any pics would be very helpful before I try to install it. Thanks
I'm not worried about the vertical aspect just that the bolts will line up. Its been done before to eliminate resonance and create a more rigid setup. I can always bend the pipe a little bit if needed however I can't rotate it.
You think it will be 40,000psi worth? Because that's how strong the welds are. There is also flex in the whole system I'm not welding the pipe to the car. You should actually know what you're talking about before you post here. If you don't have an answer then don't reply.
Unfortunately I am painting the car now and didn't have the opportunity to mock it up with the car. I got it welded at school with some other custom fab that would've cost me 3 times as much anywhere else with probably half the quality that I got. As for the bolts loosening, loctite. The flex pipe doesn't eliminate the exhaust shaking so much it would be able to be considered like a damper like you're speaking of the difference in that of a hard pipe being put in place of a flex pipe is minimal in that aspect. The flex pipe is merely there for fitment. The flex pipe is out now and is pretty rigid imo. Basically any pics of aftermarket headers installed connecting to the cat would be the most helpful.
^^ Talk about uncalled for behavior! The guy was just giving you his opinion.....no need to rude to anyone for them trying to assist you with some legit advice.
If it wasnt the answer you were looking for then just say thanks or ok
if the stock headers have it u need it, if the $1000 comptech headers have them, u need it. this puts a lot of stress on the welds, pipes, bolts. u dont need to have 2 flex pipes, but u need one. i know from experience.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
