help: crank pulley belt part #
4dr & I like it that way
does anyone have the part number for the crank pulley belt offhand? im trying to setup my UR crank pulley installation and dont have the instructions with me that have it listed
I have your car ('00, close enough) and the correct Gates # is K060441 for crank to alt to AC. For crank to PS use Gates K040425. I changed only the crank pulley with a UR one and these two belts were perfect. Note that if the store you go to doesn't stock Gates belts he will be able to cross these over to any brand. You need both these belts as the crank pulley is smaller (or larger, I forget) necessatating new belts of correct length. It weighs 6.5 lbs. less but also underdrives alittle too. I did not get the other pulleys as they are mainly for looks and do not help with gains much. UR even says so. BTW, I really like the gains the pulley added, a good 0-60 aid. Then get headers! Again, the stock belts will not work.....not much room for lenght changes in the idler pulley or PS adjustment bolt.
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
asahrts
09-04-2015 05:55 PM
