helms help!
Old Dec 17, 2005 | 01:46 PM
typeR's Avatar
helms help!
strut tower bar removal...i see the 2 bolts on the strut tower but i dont see how it comes off the fire wall?
Old Dec 17, 2005 | 02:49 PM
o1s's Avatar
o1s
there are two more bolts under the winshield cowl. two little access panels in the plastic. just pop them off and they are under them. i found this out by doing my three rear plugs. the three plugs that i now despise after losing close to a pint of blood from my knuckles.
Old Dec 17, 2005 | 04:25 PM
typeR's Avatar
thanks for the heads up...found it after i posted ...but just so you know you can easily remove the rear plugs w/o remving the strut tower brace...dont try to stick your hand between the brace instead lay on the upper intake and bring your right arm from underneath around where the PCV valve is....BTW the headers are a bitch by your self....but im done....
Old Dec 17, 2005 | 07:44 PM
typeR's Avatar
stock manifolds back on...those are so much easier by your self then the comps....if comptech would have just used studs in the headers instead of bolts it would have been sooooo much easier
Old Dec 17, 2005 | 08:44 PM
ThinJim's Avatar
what are you talking about?
Old Dec 17, 2005 | 09:21 PM
typeR's Avatar
im talking about studs in the headers it would have been easier to install the comptechs...like what the stock manifolds have that i just reinstalled...
Old Dec 17, 2005 | 11:41 PM
o1s's Avatar
o1s
i don't plan on changing my plugs again. next time it will be the dealers problem. and i always try to do crap as soon as it's delivered. spontanious stupidity i suppose. is it easier to get the the manifolds from the top or bottom?
Old Dec 18, 2005 | 12:10 AM
typeR's Avatar
you have to get them from the top and the bottom....you'll un bolt them fron the heads from above then the A pipe from below
Old Dec 18, 2005 | 01:25 AM
o1s's Avatar
o1s
ok i was talking about the actual manifold to head part.
holografique
Sep 1, 2015 07:54 PM
niner555
Jun 16, 2006 04:52 PM
cl_dude7
Feb 16, 2004 06:29 PM
juniorbean
May 8, 2002 07:24 PM
