Hello all -- Newbie to car-modding :)
How's everyone doing? i recently got an '01 CL-S and I'm pretty excited! i've never driven a sports car before, this thing is a ton of fun to drive.
i'd also like to start modding it too but i've never modded a car before.
here's a picture:
it's not even tinted yet! that's probably the first thing i'll be doing. but i'd like to clean up the inside a bit too. the most noticeable thing is this tape that's coming off from the sunroof, any ideas on how to replace it?
i'd like to do it myself without having to go to the dealer.
the first thing i did was ordering some M6 Polargs for the foglights because the stock ones are fugly. i like the deep red color of this car.
i have a question though. how can i blacken the headlights? i tried searching but found nothing. i was also thinking about clearing too, but i don't know if it'll match well with the red color. what do you think?
thanks!
here's a picture:
thanks!
Welcome to Acurazine!
you can just rip that tape off, not sure why its even there.
for the headlights, you'll have to bake them if you DIY or buy 03 headlights.
Clearing/Painting Headlights
https://acurazine.com/forums/showthread.php?t=69798
I got that link from the 2G CL info thread, check it out. its at the top of the page.
great choice on the polarg bulbs. you may have to sand down the side a little cause the bulb is a little big.
if you would like any mod ideas, just give us a hollar!
thanks. it's got 60k on it, one owner that took care of it.
i'll go ahead and take that tape off. i wasn't sure why it was there either.
i'm debating on whether to keep the gold emblem or to replace it with silver. i'm not sure which one looks better yet.
as for the headlights, i don't think blacked out looks good with the red color. i might just go with the 03 headlights. they look nice. does it matter if i buy OEM or at a junkyard?
also, on the driver's side... the arm that contains the window buttons (not sure what to call it) the interior is kinda pulled out a bit near the edge. i'll post pictures in a bit. anyone know how to fix that?
does the trunk have gold on it too?
well when you say blacked out, you mean the housing inside is painted right? cause i wouldnt tint the outside of the headlights. if you paint the outside yourself, then thats a cheaper way to get the look of the 03 headlights. and i would buy them at the junkyard. they are already kinda expensive but the dealer will cost you an arm and a leg.
this is what DIY painted housings look like. 03s look very similar.
and im guessing you mean near the buttons, the arm rest is kinda seperating out like this?
Welcome, looks good! Def tint it out helps keep the leather new, and keeps one cooler in hot weather. As for the gold emblem/grill, me personally I hate the gold package and would change it, and would also pull off the pinstripe
60k not bad
I'm not a fan of the gold Embls. but if i had a red cl i would paint them gloss black.
OEM lamps are to expensive. Find a yard that may have them
Nice find dude, keep us posted on upgrades
X2 on the pinstripe
X2 on the pinstripe
yea i plan on removing that pinstripe. it is ugly.
i'm not too fond of the gold either but it was a good deal and i plan on playing around with it. once all the tinting and these small little upgrades are done i plan on getting some wheels and then work on dropping it + other exterior stuff.
painting the lights are cheaper but some people dont like to do it and it can leak on you if you dont close it up correctly. but many have had success. I suggest you go look at the DIY before you decide.
if your trunk has it too, then its gonna be kinda hard to find all the emblems (unless you go to junkyard) and its gonna be a pain to replace them all. its up to you though.
as for the armrest, heres the link to fix that:
DIY Fix the gap in your armrest:
https://acurazine.com/forums/showthread.php?t=187099
Whats up with RDX owners?
Welcome. Have fun with it.
Dont forget to search the FAQs for info and also use the search function (even though it sucks). I good way to narrow down your results is to use quotes around what you are searching. e.g. "clearing headlights"
If you cant find it, dont be afraid to ask. Most of us on here have done alot of crap to these cars and we can share some tips.
Yes! I beat Noah to it!!!
Chamorro
https://acurazine.com/forums/2g-cl-frequently-asked-questions-52/d-i-y-clearing-headlights-495390/
You can fix the gap on your door handle. Its a little bit of work cause you have to take the door apart to get to it. If you search I'm sure you can find the write up for it in the FACTS section.
GL with the work. Make sure to come back if you have questions!
for the arm rest, had the same thing happening (but a bit worse... more open)... the way I solved it: clean it, scrape a bit inside, first glued with good epoxy mixture and before applying pressure used some crazu glue arround the epoxy (without letting any out)... press for 10 minutes... dont let the glue spill and spoil the outside, be very carefull, if you have to remove control after it can be done easy but you may need to re glue afterwards... most CL-S suffer from the same issues... this site is the best trouble shooting guide ever... I think even dealerships look for advise here... You will probabbly experience the clock light not lighting (1 good punch on left side will do it), engine will turn but not start (re solder fuel pump relay under steering column), erratic idling (clean IAC valve), shaking when braking (upgrade rotors and pads), brake light comes on (replace brake fluid and clean lid and sensor)... replace tranny fluid every each other engine oil change or at least once a year to provide some extra protection... love my CL-S... great mileage, tons of power (mine has no cat converter), confortable as a luxury car... reliable as death (you can always trust her), amazing trunk space, excellent value for your money... I would not change my 2001 for anything I could buy brand new in the $20,000 range... mine has 80K miles, tranny perfect (this tranny is great, besides the isues it has, it is like having a robot inside it shifting for you)... handling is awesome (obviouslly there will be performance vehicles by far superior but you need to spend some serious bucks)... where I live there are only two of them, mine that is NHB and a white one (CL-P)... I have the only CL-S 2nd generation in the whole country (I´ve seen a couple of TL s around (2 or 3) and a first gen CL... so it stands out even being almost 10 years old! I drive 100 miles to work every day, part of the route is a highway where I kick some serious ass every day cruising at 120 mph easily (I see beemers and Lexus disappear on rer view mirror)...
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
With the door comming apart issue the easiest way to fix it (well the way I used) was get some gorilla glue or epoxy clean it put the glue on it and get a Shower curtain holder (spring loaded) And pop it in there so it is pressing against both parts of the door thats comming apart. My shower curtain holder / bar fit perfectly and that way you can keep alot of pressure appliad for a long period of time w/o getting your arms tired..
B A N N E D
The best upgrade I ever did to this car was lowering it a inch and a half.
Improved the look and handling, I went B&G shocks and springs for less then $500 shipped and car handles and lookd lovely... Also when paired with a progress Rear sway bar ($150) w/comes with polyuritane bushings, the handling increases dramatically compared to stock.. I also changed from sway bar bushings with polyurethane and got some MOOG sway bar links front and rear which is less the $90 and they are 2x beefier and greasable while on car (has grease nipple)... If u do that then the car is gonna look 3 X better and take turns double the speed stock w/minamal body roll.. I sometimes foget im driving a FWD car where 70% of the weight is under the front wheels...
Then power headers are your #1 HP gain... u have a few choices for Auto Megan Racing and OBX can be found under $300 shipped then there is commptech and DC sport
Headers will give you 15-25 hp alone...
Then there are CAI or comptech Icebox or just removing the resonater or whatever (i am not familiar w/this but many here have tried this)
Then there is a lightwieght pulley Unorthodox racing has one for a couple hundred i think by OPtion makes one on Ebay that i got for $25 and works fine just gotta get diff belts cuz the pulley is smaller.. Some say the tach rises quicker and get some power but minimal i felt nuttin... but can u feel 3-5 hp?
Then Outlaw engineering makes TB and IM spacers and some other company makes a TB spacer PR2 or P2R and the also make pleniums (sp) that will add a few hp (might as well go do the 3.7 TL IM swap instead..
Thats some of the stuff I did oh yeah Brakes...
You can do a legend coupe or NSX caliper swap and change those single piston fron calipers to daul pistons OR spend a crapload and get a big brake kit Brembo , stoptech , willwood I think make then for our car and I think the wilwoods are the cheapes u can find the for $700-$800 cuz the stock brakes DO SUCK and do WARP!
B A N N E D
OH yeah WELCOME aboard and I think the GOLD emblems ONLY look good and the san marino red (or whatever they car that red) The gold goes GREAT with the red Leave it alone...
I forgot to say that comptech makes a SC but $4000??
where do you live huh?
DunesCreations
09-09-2015 12:03 PM
n2booz
09-28-2004 05:35 PM
