Heater Circuit Code
Old May 8, 2009 | 02:23 AM
tnobori1's Avatar
Missing my
Heater Circuit Code
I replaced my o2 sensor after putting in headers a while back, but I still had my CEL on. Pulled the code today and found that it's the heater circuit on my pre-cat o2 sensor. Anyone have any ideas how to fix this without replacing the whole sensor?
I used the OEM sensor, so it came with the harness attached. Is this a fuse issue? Harness issue? Any advice is appreciated!
Thanks!
Old May 8, 2009 | 04:46 AM
Rajca's Avatar
wham bam thank you ma'am
check out the fuse, check out the connection point. it should have warranty right?
Old May 8, 2009 | 11:46 AM
tnobori1's Avatar
Missing my
Let's hope so, I got it from acuraoemparts.com... Do you know which fuse it is?
Old May 9, 2009 | 12:42 PM
tnobori1's Avatar
Missing my
anyone know which fuse it might be or have any other suggestions for me?
Old May 9, 2009 | 12:51 PM
Rajca's Avatar
look in the fuse panels by the driver side door hinge and the same spot on the pass side. it will say "FUSES" or something like that
Old May 10, 2009 | 02:29 AM
tnobori1's Avatar
Missing my
Thanks Rajca! I actually know where the fuse boxes are, I just didn't know if anyone happened to know which fuses I should look to replace. Some of them are obvious, but some are kind of ambiguous.
Old May 10, 2009 | 09:29 AM
Rajca's Avatar
look for any that says o2sensor or heater, also look in the fuses under the hood. if i cant find what im looking for, i just take them all out one by one. takes a bit longer but that eliminates the possibility of a blown fuse
Mike Pilipenko
Mar 26, 2024 09:21 PM
Jamus22
Jun 11, 2023 10:08 AM
07Acuradude
Sep 29, 2015 03:01 PM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
