Headlight Problem...Can anyone help???
Old Jun 15, 2005 | 04:14 PM
MeaghanA's Avatar
About three weeks ago I turned on my headlights and the passenger side headlight was out. The next morning i went to the store to buy some new headlights and when i got home to replace them, the headlight was working. For about 2 1/2 weeks i had no problem with it. Well, about 2 or 3 days ago I turned on my headlights and the passenger light was not working again. As i was driving down the road i turned my headlights off and then back on. When i turned the headlights back on both worked fine. Has anyone experienced this before or does anyone know what could be going on? Thanks in Advance.
Old Jun 15, 2005 | 04:41 PM
Shadzilla's Avatar
Could be a bad ground.....did you recently put in an icebox?
Old Jun 15, 2005 | 05:02 PM
MeaghanA's Avatar
Re:
I have no modifications.
Old Jun 16, 2005 | 02:10 PM
GEB's Avatar
GEB
I don't know if this will help but my 85' mustang had the same problem. Ended up being the High beam/Low beam switch on the column. If they go out again, try flashing your High beams.
Old Jun 16, 2005 | 02:38 PM
Lord Helmet's Avatar
I'm here in spirit...
Could it be a bad balast (did I spell that right?)? Don't HID's have one? I don't really know too much about HID's. I just turn mine on!
Old Jun 16, 2005 | 03:09 PM
CL-S Girl's Avatar
Hi, I'm new.
I had this same problem last week with BOTH of my headlights...they flicker and go out, and when you turn them on/off a few times you can get them back on. First it was the passenger, then the drivers side did it too. with HIDs, it could be one of a few different components of the headlight. It's probably either a bad ground or the igniter is going bad. I think in my car they decided it was the igniter...
....but since my car is still under warrantee, i just had them replace it all. Good luck.
Old Jun 16, 2005 | 03:14 PM
6MTpromises's Avatar
Relax!
^ Id have to agree w/ her on the igniter. If you do a search a lot of ppl had the same problem which turned out to be the igniter. Do you have any warranty left? If so, take it in itll cover it.
OH, and welcome CL-S Girl!
Old Jun 16, 2005 | 04:16 PM
m&b6speed's Avatar
buy my car
i had my passenger side low beam shatter. no moisture nothing in the housing. but for a day or two before that it made a strange humming noise when turned on that was only hear outside the car. did you guys/girls hear a noise like that??
Old Jun 16, 2005 | 10:21 PM
MeaghanA's Avatar
Well today i when i left work i turned on the headlights. The passenger side light did not come on, so i thought i would try the trick of turning them off and then back on. This time the light did not come one. I tried to turn them off and on a few times to see if it would come on, and it did not. Does this still sound like a bad ignitor? Thanks for your replies guys.
MeaghanA's Avatar
Well today when i left work i turned on the headlights. The passenger side light did not come on, so i thought i would try the trick of turning them off and then back on. This time the light did not come one. I tried to turn them off and on a few times to see if it would come on, and it did not. Does this still sound like a bad ignitor? Thanks for your replies guys.
Old Jun 16, 2005 | 11:23 PM
AMorgCLS's Avatar
Girls luv me Guys hate me
It could be a couple of things MeagheanA. Ballast or Ignitor. Like previously said, if you're still under warranty, take it into the shop for warranty repairs. Hope that helps...
BTW Welcome to the forum, MeagheanA and CL-S Girl Glad to see more chicks here
Old Jun 17, 2005 | 08:37 AM
CL-S Girl's Avatar
The balast and the ingniter are sort of connected, technically they'd have to replace both. It's still probably the igniter, my passenger light wouldn't come on at all for a while, then came back after a day or two, then went out again, etc etc etc.
But no, I didn't hear any noises from the headlight.
Old Jun 18, 2005 | 02:40 PM
AMorgCLS's Avatar
Regardless on whether or not you hear any noises, if you're still under warranty, take that bad boy in and have it fixed (for whatever reason). I mean, that's what you paid for, so why not use it
Old Jun 20, 2005 | 01:54 PM
MeaghanA's Avatar
Alright so my car isn't under warranty because it was wrecked by the previous owner. But i was thinking about this problem the other day, and when my car was wrecked it was hit on the front bumper on the passenger side. I don't know how long ago it was wrecked, but do you guys think that the accident happening on that part of the car would cause this problem? If not, where could i find where to check/fix/replace the ignitor first?
Old Jun 20, 2005 | 07:46 PM
m&b6speed's Avatar
buy my car
your car being in a wreck shouldnt void your warranty-unless you have a salvage title.
and if the wreck was to that side, something definately could have been damaged and not replaced/fixed right. you need to find a mechanic who works on cars with HID's, cause they will understand how they work-not that they are hard-just that they may have more experience
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
