Headlight fogging
Old Dec 28, 2005 | 01:34 PM
sexytypes's Avatar
sexier than the sexiest
Headlight fogging
Hey guys, i just installed 03 headlights and they were new, and one of them is fogging up pretty bad the condenstaion inside is ridiclous, what am i suppose to do, i figure maybe if i disconnect the hi-beam and ride around with my headlights on then it would dry it up and the moisture would air out through the hi-beam hole, but still, any suggestions, blow dryer, hot air gun?????
Old Dec 28, 2005 | 01:39 PM
tommyt1's Avatar
you might have to dis-assemble the headlight from your car and put it in the oven on low which will melt the glue and you can take the headlight apart. then you can clean the light housing and what not and re seal which will prevent any future fogging. i do not have EXACT instructions on how to do this but its been done before. im sure if you google it, it will come up.
http://www.honda-acura.net/forums/sh...threadid=56277
try a few of those instructions, just skip the painting etc.
Old Dec 28, 2005 | 01:45 PM
sexytypes's Avatar
no other way around it, dont really wanna do that whole procedure the damn light is brand new!
Old Dec 28, 2005 | 02:12 PM
123456SPEED's Avatar
CLS 6MT Navi
I'd try to return it if you got it from a business.
or
You could install it in someone's 03 CL and have the dealer replace it under warranty. I know it's not totally ethical but neither is selling faulty headlights that cost $300. I've had one replaced already and the other one fogs up occassionally.
They may question it if it looks new & the other light is aged or damaged on the 03.
Old Dec 28, 2005 | 02:25 PM
sexytypes's Avatar
I Bought It Off Ebay
Old Dec 28, 2005 | 03:13 PM
Lord Helmet's Avatar
I'm here in spirit...
My right one does the same thing and it's getting worse. Luckily, I got another set I'm going to clear and paint so that should fix that problem.
My question is though, is this bad for the headlights in any way??? The bulb and the invertor were just replaced in this same headlight about two months ago. WTF!?
Old Dec 28, 2005 | 03:45 PM
jherb's Avatar
I would try your first thought, taking out the highbeam and running with your lights and see if that drys out the light. If that doesn't resolve the issue than I would do what tommmyt said.
Old Dec 28, 2005 | 03:50 PM
03silvertypeS's Avatar
bake them, take them apart (might as well clear them while they're out, maybe paint them) and seal them properly
Old Dec 28, 2005 | 07:34 PM
OneFlyCL's Avatar
If its still clean you can just add extra sealant around the cracks and corners to seal everything up. That's what i did and it worked......sorta
hashbrown
Feb 18, 2022 11:20 AM
Avenger411
Oct 11, 2015 03:53 PM
Mr.Tea
Oct 2, 2015 10:32 PM
rockyboy
Sep 29, 2015 12:05 AM
rhdune16
Sep 28, 2015 11:31 AM
