Headlight aim after lowering?
Old Aug 11, 2004 | 10:20 PM
DPOLICH's Avatar
For those of you that have lowered your CL's with a Comptech drop; did you re-aim your headlights higher to compensate for the drop?
Old Aug 11, 2004 | 10:24 PM
Shawn S's Avatar
YES…definitely.
Old Aug 11, 2004 | 10:45 PM
Red-CL's Avatar
Doin' da crack shuffle
I never did.
Old Aug 11, 2004 | 10:49 PM
blader's Avatar
Audi S4 driver
I didnt for a while and wondered why my headlights didnt seem as bright. Then it dawned on me
I aimed them a tad bit higher than they were with stock suspension. Lights up the road very nicely now but occasionally I get flashed by people because they are too bright. Oh well they can deal with it
Old Aug 11, 2004 | 10:53 PM
Chopsie's Avatar
Beware of leakage
I adjusted mine, but I think they came out like Blader's
Old Aug 11, 2004 | 11:58 PM
darrinb's Avatar
///M POWER
mine are very high, i get lots of flashes
Old Aug 12, 2004 | 12:07 AM
NiteQwill's Avatar
Adventurist.
Easy fix with a screwdriver. Do it!
Old Aug 12, 2004 | 12:26 AM
blader's Avatar
Audi S4 driver
I prefer them a tad higher than stock, lights up road signs and side of the road reflectors very brightly. almost eliminated the need for high beams. However, the other drivers dont prefer them where I prefer them
Old Aug 12, 2004 | 12:30 AM
darrinb's Avatar
///M POWER
the visibility does get alot worse id u dont higher them after lowering the car
Old Aug 12, 2004 | 01:47 AM
Silverbulit40's Avatar
Enjoy the Ride
i have a Eibach Prokit drop and never had to re aim the headlights...maybe because autos are heavier up front??
Old Aug 12, 2004 | 04:29 AM
FunkeeTown's Avatar
friend of fast
never noticed any change after h&r sports drop. man, if u point our headlights up at people they will burn their cornea out. it's like staring into the sun at noon. nasty stuff.
Old Aug 12, 2004 | 06:01 AM
Shawn S's Avatar
The first time I drove in the dark after getting the Comptech springs installed, all I had was two circles of light on the road about 15FT in front of the car.
The very next day is when I learned how to adjust the headlights because I could never have driven around like that.
Especially out in the woods here where spotting deer and other wildlife is essential for safe night driving.
Shawn S
Old Aug 12, 2004 | 07:44 AM
fuzzy02CLS's Avatar
Adjusted mine up a little. They are back at about stock level. I don't get flashed. And had no problems seeing at night on dark roads on my trip to NYC.
Old Aug 12, 2004 | 08:20 AM
ChadT's Avatar
Spectacular Aroma About
I think the pro kit sits about level compared to stock. Definitly have to re-aim with the Comptech rake.
Old Aug 12, 2004 | 09:23 AM
Enjoy the Ride
I thought the Eibach sits lower? I know the front is dropped to 2.0. I think comptechs are somewhere around 1.7 or 1.5?? correct me if i'm wrong.
Old Aug 12, 2004 | 09:37 AM
ChadT's Avatar
How low the car is shouldn't have much impact on the headlight position. THe comptech springs lower the front much more than the rear so the headlights end up pointing towards the ground and you need to raise them to see. You could slam the car to the ground and as long as it was at the same angle front to rear as stock the headlights would not need adjusting (at least not as much as when the angle of the car is changed).
Old Aug 12, 2004 | 09:50 AM
Chaptorial's Avatar
Have yet to adjust them since the drop.
Old Aug 12, 2004 | 12:39 PM
joseph_99tl's Avatar
i need to adjust mine..
Old Aug 12, 2004 | 04:11 PM
DPOLICH's Avatar
Adjusted mine last night. Adjusted to the pre-lowering level. Much better now, just like before the lowering.
Old Aug 12, 2004 | 04:14 PM
VeeralS05's Avatar
I NEED MONEY!
How do you adjust them?
Old Aug 12, 2004 | 04:21 PM
DPOLICH's Avatar
Looking down from the top behind each headlight assembly is an adjustment mechanism.
This looks like teeth or gears that are then rotated by using a phillips screwdriver when
turning the teeth with the phillips head. This is the adjustment for height. There is another adjustment mechanism for side to side. This is not necessary after lowering.
Old Aug 15, 2004 | 09:19 PM
Shawn S's Avatar
LOOK FOR THIS
INSERT PHILLIPS SCREWDRIVER & ADJUST AWAY
Old Aug 15, 2004 | 09:28 PM
VeeralS05's Avatar
I NEED MONEY!
and thts right behind the headlight housing?
Old Aug 15, 2004 | 09:30 PM
Shawn S's Avatar
No, it’s in the trunk.
YES, of course it is.
Old Aug 15, 2004 | 11:26 PM
dark inspire's Avatar
El Presidente
which way do you turn to raise them? clockwise or anticlockwise?
Old Aug 16, 2004 | 12:17 AM
NiteQwill's Avatar
Adventurist.
It's printed right on top of the black plastic cowel above where you adjust them: like this U<------>D
Old Aug 16, 2004 | 12:21 AM
El Presidente
thankz
Old Aug 16, 2004 | 07:02 AM
Red-CL's Avatar
Thanks for the pics Shawn.
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
San Yasin
Sep 29, 2015 10:52 AM
rhdune16
Sep 28, 2015 11:31 AM
