HEADERS (do you really notice a difference?)
#81
My Work is Done Here
1 Post
Originally Posted by 02CLNOS
When i start the car it makes a zizzing noise, Also sounds like valve tapping. All the bolts are tight and gaskets are good but i don't know. I guess i'll give it until the end of the week to see if it solves it's self. Any thoughts are welcome
That sounds similar to the problem I had when I fist installed the XS headers, with their gaskets. Switched them out for stock gaskets and all was well.
#82
I went ahaid and got stock ones and that's the noise it makes..... i couldn't figure it out todaybut i will have to loosen them up and tighten the headers frist then where the connect to the a pipe than cat.
#86
2003 Acura 3.2CL Type-S
So after reading this thread it seems like short of Nitrous or the Supercharger Kit a header is the best bang for your buck modification to make power out of the CL, is that correct? Just wondering because I know on the Prelude the DC Sports and other Production Headers like that had minimal gains if any, the only way to get gains was out of a custom header from Hytech or SSR or something, seems like that's different for the CL?
#87
Don't Mess With Texas
the air is not flowing smoothly through the pipes around the welds which in turn causes the resonance.
#88
I Wanna Beer
#89
Originally Posted by TheWeez
That's correct. Header is will add the most power short of NOS or supercharging. Getting an air intake like Comptech Airbox is the next best and adds something like 14hp.
#90
I Wanna Beer
Originally Posted by p.diddy
intake does not add 14hp more like 3 to 5.
I gained about 16 ft-lbs of torque at 3500 rpm
and i gained about 16 hp at 4500 rpm!!!!
#91
I could have sworn that the Comptech airbox added at least 10HP. This is from an old thread when the airbox first came out. Dyno'd stock and with the airbox on.
#92
I'm going to work on her tonight. i'll fix this leak ... Oo yes ....i will.
Shit, if their was an intake that would give you 14hp... its an E-RAM (HAHAHAHA) thoes things are funny stuff! has anyone tried them befor?
#93
I Wanna Beer
E-Ram just causes an obstruction more then anything else. There was a car mag a while back that hooked a leaf blower to a Mustang intake and they were able to get several PSI of boost though.
#94
i heart latin chicks
#95
Well i got them to stop leaking. They are LOUD at higher rpm's, massively loud, I love them. I didn't get into them before becaues of the niose it was making but i got into her today after work and SHIT,... you can feel the differance. It grabbs the shit out of 2nd.
All & all I don't like the fitment that much because i had to get a pri-bar in their and move it while i was tightening the bolts ..... but no leakes now, so i'm loven them.
Thanks to all you guys for the info and sorry for kinda taking over this post.
i what to post picts but we all know what they look like.
#101
Regional Coordinator (Texas)
i just installed my xsp headers today. started at 5, finished at 6:30. it was two of us working on the car, the motor was fucking hot.
also took off the strut bar, just for the hell of it. and yes, it did make accessibility a little easier.
it was done on a lift too.
I wrapped the complete down pipe w/ exhaust wrap. wrapped the flex pipe twice because i had all the xtra wrap sitting around.
I did buy the bolts/nuts/locking washers from home depot.
The only problem i have now is that the headers and the down pipe didnt line up properly, they're a little twisted around, by about 5 - 10 degrees. will have to get fatter bolts to fix that.
power wise,
1st gear, almost the same
2nd, little better
3rd, WOW
4th, eh . . .
5th, didnt have space to go that far!
I did waste about 3/8s of the tank in less than 30 miles!
I think adjusting the angle of the headers and the downpipe connection should make it a little better because its off by a little bit.
power wise,
2nd, little better
3rd, WOW
4th, eh . . .
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
