header install.... what is the best way.?
There's a re-occurring issue that always arises with this install. Some say do the back header from the top and some say from underneath? Moreover, how hard is this?
I'm sure there is a sight I have overlooked/missed with this precise info.
If you could show me the way I'd be greatly appreciative!
* Just want to know everything b4 they arrive so I can install them Pronto without snags.
Moderator Alumnus
It doesn't matter which header you release first.
It's not complicated. Just nuts and bolts need to be released then tightened down. For the average mechanic joe it should take about an hour or less.
Moderator Alumnus
There are two informative readings in the 2nd gen info thread. Click the first link in my sig.
Here's one:
https://acurazine.com/forums/showthr...d.php?t=461011
Here's one:
Unbolt/bolt the header from the top. The nuts are too far to reach from the bottom.
Remove/install it from the bottom. There's not enough room to squeeze it in from the top.
Front headers and pipe connections were easy......for the rear, I just layed across my engine, to reach back there with a crescent wrench and a small breaker bar. I advise spraying some PB Blaster on the bolts for 2 days before attempting the un-install/install
Whats up with RDX owners?
Make sure the bolts connecting the J pipe to the cat arent rusted on. I had that with mine and had to cut them off.
The front header comes out from the top. Unbolt both front and rear from the top. To take out the rear, get it from underneath. Dont tighten everything until you have it all installed.
Make sure you use OEM gaskets for the cylinder head -> header.
13.2 @ 104.76mph
I would advise to either use the stock bolts, or purchase some new ones from a hardware store.....and the gaskets that come with the headers are crap.....they feel like 1/8" cardboard. So be safe and listen to the guys who are giving you the advise.
Trolling Canuckistan
Take the advice of those who have done this before you so you can do it right the first time.
Some people reused their original gaskets, some bought new OEM ones. Either gaskets are relatively cheap in the grand scheme of things as are bolts.
I strongly disagree with it being a short or simple job. Some have got them in quick & easy, some it took days.
While the job should be easy, getting rusted tq'd on parts off a 7+ year old car can be a PITA. Your cat bolts are going to be a bitch for sure.
idk how you guys are able to use bp blaster to loosen stuff. never worked for me on the 87 suburban I had. I soaked bolts for a week & still had to cut them off.
It took me about 8 hours to do the whole job. It would have been quicker if I didnt have to sit under the car with a grinder and a cut off wheel with less then a foot of space.
It helps to have an impact wrench on hand. If you don't have one, then a really big breaker bar may do the trick. Also, a nice torch helps. Just dont strip any bolts as it will complicate things tenfold.
I can definately understand why someone would want to take it somewhere to get it done. But I refuse to let someone else modify my car. So I will shed all the blood, sweat and tears my body has to give to do the job myself.
I think a good test to see if you can do the job easily is to try unbolting the cat bolts first. If those come off easily, you shouldnt have a problem with the rest of the install.
wow rust??? Lol I must be the luckiest guy around then...
This car's been in toronto it's whole life and there is not a drop of rust anywhere. The engine bay area looks brannn new
I'm going to post you up some picks when I get my canon G7 working again. It had one owner and was parked underground it's whole life and now it's garage kept. only thing with signs of rust are the cat, a TAD on the exhaust and the rear heat shield...
And I'm extremely NITPICKY when it comes to rust or cleanliness on my WHIP. She deserves better
Your mom is in
I completely agree, make sure you look at the cat bolts..mine might as well been welded on the rust was so bad...
Here's one:
Here's one:
The one thing I found was that the install went smoother when all of the components were loosely fitted first. Headers to manifolds, cat to downpipe, then I tightened/torqued the header bolts then tightened/torqued the cat/downpipe connections. There were no initial leaks. I went back a week later and re-torqued the header bolts and they have been on ever since, trouble free.
In addition, the PB blaster and the swival sockets were very helpful to have on hand as well.
