HBP upgrade question.
I have a CLS-6 with a few ticks under 100,000 miles. The supercharger has been installed for 85,000 of it with no problems and the original clutch.
How wise would it be to switch from the standard pulley to the HBP? I do not have emanage or anything of the sort so I couldnt get it tuned. How many people are out there with the HBP and have not had it tuned? Any problems?
I would do it after my 105K service but do you thing adding more boost to an engine with that many supercharged miles is wise?
Thanks for the input.
I've had the HBP on since the initial install of my S/C'er and it was one of the best upgrades I have made.
Never had my car tuned; however, I can get the 93 octane premium gas here in Florida which helps with detonation, especially in the hellish FL heat. I'm clocking around 60K+ on the blower unit thus far with no real problems.
I have the IRMC disconnected at the distal end of the actuator cable, with the 2P switch still connected at the actuator. So far, so good.
Get the HBP, you'll love it.
Thats good to hear, 93 is not a problem here in Ohio either. It nice to see someone with that many miles and no problems. How many total miles do you have on your car? What style would you say is your driving? This is my dialy driver when not riding the motorcycle and it is usually 60+ miles a day 50 of which are steady highway and only ocassionally do I "get on it".
Also did you get your HBP from Comptech or someone else.
If I do this I will have the dealer do a compression check at the 105K service to see if the past 85,000 supercharged miles did any damage. Then I will decide.
The blower was installed at 45K, I tried to wait until 50K when the warranty was to expire; however, I could not wait. The car is currently at 106K, so about 60K+ on the S/C unit.
Much like yourself, I to use this car as a daily driver. Mainly on the highway to and from work. I'm not out to match every 'swinging dick' that rev's on me at an intersection; however, it is nice to have a 'kick in the pants' on a quick downshift from a roll when you need it.
The install shop ordered it from Comptech after I had purchased the S/C'er kit bakc in 2005.
You will probably be pleasently suprised at the results. There is a Moderator over on the 2nd Gen TL side that did a six speed swap. He's got some crazy miles clocked up on his J-series engine(s). At 105K these things are just getting broken in with consistant maintanence and reasonable driving.
Good luck!
Good luck!
What to do, what to think
No your statement is based on ignorance. I have went through 3 motors due to no tune that eventually all gave out due to silent knock. So my statement is far from ignorance, its from experience. The FPR provided by comptech coupled with the higher boost without ignition retard (6psi) will eventually kill a J32A2 motor even with colder plugs. I remember you from v 6 p so I am accustomed to your "wise ass" remarks. I am also not here to argue, I was and am merely making a statement based on my own personal experiences. But of course the all knowing such as yourself would have something to state and remark in the contrary.
It sounds to me like your FPR was incorrectly calibrated, your IMRC was not disconnected, or you screwed something else up.
Dozens of others have individually driven 10's of thousands of miles without failure. Your ancedotal evidence to the contrary is not enough to go around telling people to spend hundreds of dollars on labor and equopment they don't need.
I don't think I've ever posted on so not sure who you're talking about. I've owned 2 supercharged CL-S's, bot with the HBP. Two different cars, two different blowers.
mlody
12-04-2019 02:11 PM
InFaMouSLink
10-30-2015 09:43 AM
