Haze over head lights . . .
8-1/2 year old CL-S and the foggy exterior haze on the headlight housings is becoming very noticeable. What can be done to clear them up? Plastic polish? Super fine grit paper? TNT?
Hey Dan, I used a mcguiars product (forgot the exact name, its in a black tube) called plastic-x or x-plastic. worked very w/ a 1000 grit wet sand paper.
got mine looking brand new. i took the whole headlight out and did it inside, took maybe 30 minutes a headlight, and when you wet sand you want to keep doing it until all the milky liquid comes off.
Dan,
Quick How-To but you can find more detailed DIY's using the SEARCH option.
I have some threads with pics from when I did this back in the spring of '08.
Meguiars Plastx.
1500 grit
2000 grit
2500 grit
Start with 1000 grit if really bad.
Mask off headlights with auto paint tape.
Wet sand lightly over each headlight using same pressure.
Clean headlights after each round of sanding.
Apply Plastx by hand with foam applicator.
Several passes with Plastx is what I needed to complete the effect.
You CAN do by hand but for best results use an orbital buffer or borrow a friend's Ultimate Detailing Machine...helps a LOT!
Clean and enjoy.
Meguiars Plastx.
1500 grit
2000 grit
2500 grit
Clean and enjoy.
Your mom is in
OR...
if you want to avoid buying all that sand paper separately...
theres a kit made just for this job, with all the sand paper you need, and the chemicals...its called Crystal View, and can be found at your local Advance Auto Parts store for $19.99
sorry if that sounded like an advertisement..
OG 3.x^7 rawr
OR...
OG 3.x^7 rawr
yes, the haze is on the outside. you just have to be careful when sanding if thats what your doing. I would bust the painters tape out and apply that around the headlight before sanding.
bye Acura, hello Toyota
I have had good results using 303 Aerospace Protectant on my interior as well as the exterior black rubber trim. I will be resurfacing my lenses this weekend and will give it a try on them.
RLX-Sport Hybrid
3G RLX (2013+)
43
12-16-2015 10:45 PM
